    Default Noise at high speeds in front driver side wheel area
    I have a 2003 chevy silverado that has a weird muffle whooble noise in the front driver side tire area. It was very loud a month back so I did a complete break job (discs + rotors) and now it is not as bad but it is still there. Anyone have any idea what it could be? Bearings? other? The truck tracks well so I do not think that it could be an alignment issue. Thanks!
    murdog94's Avatar
    Sounds to me like it is a bad pass front wheel bearing.. they cost around $100-$130 and take about 45 min to change.
    Mike
    Currently
    2011 F-150 Crew 4X4
    Is this a situation where I should replace both front bearing assemblies at the same time or should I do them as I have problems? Thanks for your prompt response.
    Quote Originally Posted by ccpotter View Post
    I agree 100% with Murdog, on the problem being with the front Wheel Hub Bearings.....its a common Problem on these model Trucks/SUV's......On replacing them both it all depends, I would say that if your Budget allows you to replace both of the Wheel Hub Bearings at the same time go for it......Check both and if you feel that the other one has no problems at this time, you could replace it later when your Budget allows for it.....but keep an eye on it.
    Edit:....When I replaced my Bearings.....$$$ was Tight, I did One and then the other a month later.
    x3. sounds to me like the bearing!
    J. Roy
    2010 Silverado Z71 4x4
    33/12.50/R20 Cooper Discover STT Tires
    20" KMC XD Monsters
    Rough Country 2" Leveling Kit
    Rancho Shocks
    Airaid TBS
    Volant CAI
    8000K HID Head Lights
    6000K HID Fog Lights
    Tinted Head Lights/Fog Lights and Brake Lights
    Blacked Out Completely
    murdog94's Avatar
    And living here in MN i agree with the change as money allows. to bad your not in the local area to me i could help you knock it out!
    Mike
    Currently
    2011 F-150 Crew 4X4
    Jr. Apprentice Zzyzx's Avatar
    May 2010
    Phoenix, AZ, USA
    If you can afford to do both at once, definitely go for it. I just did it recently, and the truck drives like a dream. I hadn't realized how bad it really was, just a weird noise at 65-70, but now it's quieter through all the speeds. I think it's just one of those things that sneaks up on you. On these trucks, it's a part you're lucky to get 100k out of. (Mine needed replacing at 97k or so, I believe.)
    Don't lose your mind trying to set it free.
    2005 Chevrolet Silverado 1500 CC 4x2 5.3L
    Thanks all. I will hopefully be tackling it this weekend. The truck is around 90k for miles so make sense and Minnesota salts seem to reek havoc on vehicles fast. Thanks for your responses. I will report back when I am done.
  1. Replies: 8
    Last Post: 06-07-2011, 08:41 PM
  2. 1993 suburban 2500 4x4 clicking noise in front tire area
    By robdoggydog in forum Wheels & Tires
    Last Post: 05-24-2011, 07:26 PM
  3. Rubbing noise when rolling down driver side window
    By eanderse in forum General Chevy & GM Tech Questions
    Last Post: 05-11-2011, 09:53 AM
  4. Popping sound coming from front driver side
    By DarkCherry in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 09-24-2010, 10:17 AM
  5. Thump or pop fron front driver side
    By Fusefinder in forum Chevy S10 Forum (GMC Sonoma)
    Last Post: 09-05-2010, 07:26 PM
