Results 1 to 9 of 9
    Default 95 Silverado idles slow (too SLOW) 600 rpms! help
    Hello, I am having diffuculty with my trucks idle. Its a 95 SIlverado, it only idles at about 600 rpms all the time. It does not stall like this but it concerns me. It has been chiped and I am currently only running 93 oct. It is also TBI. What could the problem be, I have troubleshooted and I am coming up with nothing. Could it be the throttle pos sensor or the idle pos sensor. I just cant understand what would cause this. Can I manually adjust the idle myself. Its not a vortec.
    Have you cleaned the throttlebody and IAC lately? I like to remove the throttlebody so I can clean the bottom and top with a soft toothbrush and throttlebody cleaner. Also take off the IAC valve that is mounted in the t/body side and clean the pintle with the cleaner. This pintle moves in and out to control the idle. It gets carboned/gummed up and can't move freeely in and out to control the idle.
    :cool:
    Weather Tech floor mats
    Cover-Craft seat covers
    Dash mat cover
    Formula One window tint
    One black Lab in rear seat.
    :glasses:
    No I have not cleaned it latley. It is always at like 600 if ur in drive and its real annoying. It cold starts and idles right but once it gets to working temp it comes down to 600-650. It also has a prob above idle like at 800 rpm if ur going real slow it likes to surge. could this be a dirty TB. CAN I ADJUST IT?
    I would start with a good throttlebody cleaning. If you haven't done this in awhile its not going to hurt. Don't use carb cleaner!
    You shouldn't need to adjust it. As mentioned, give the TB a good cleaning with some TB cleaner and a toothbrush. Remove the IACV so you can clean the port thoroughly. Slow idles is not a common problem on these trucks, fast idle is....
    Is 600 in gear, foot on brake?
    yup, in gear with brake applied. I will try this. Also could the TPS have something to do with this, it has been surging. sometimes at stop signs it acts funny and drops rpms just a little and then catches itself and comes back to idle. only 1 time this happened and I got some trottle body cleaner and sprayed around the trottle plate and it never happened again. Also a few weeks ago I got a check engine light and the idle was normal so I shut the truck down and started it back and it went away and its back low again. Any more ideas??
  1. Replies: 3
    Last: 04-14-2010, 12:23 PM
  2. Slow windows
    By TheChadders in forum Chevy Silverado Forum (GMC Sierra)
    Last: 02-07-2009, 08:11 PM
  3. Slow Silverado
    By skoal bandit in forum General Chevy & GM Tech Questions
    Last: 11-15-2008, 02:24 PM
  4. slow brakes
    By Sandro in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 02-27-2008, 10:57 AM
  5. Slow day!
    Last: 07-27-2005, 05:24 PM
