GM Truck Club
Results 1 to 6 of 6
    Default Torque converter = Engine problems?
    I have an 84 GMC 1500 2WD 350. Here's what's going on. When its in park it runs great. Revs up fine and sounds good. When I put it in drive it will take off fine if you go slow. When you push the throttle down it boggs the engine. You let off and baby it and it runs fine again. I've already replaced the whole ignition system and the distributor is advancing. Any ideas? Could it be the torque converter?
    Legend
    murdog94's Avatar
    Feb 2008
    Cloquet, Minnesota, United States
    Sounds more like a carb tuning issue to me. I knew you were having issues with spark stuff.. and being parked there is a chance you have an issue with the accelerator pump etc in the carb. I would start in the carb anyway because if it was a TC issue it would be pretty much under any engine load
    Mike
    Currently
    1997 Chevy S-10 Blazer 4X4 with 330K miles and counting (Hunting rig).
    2009 Saturn Aura XE (wifes car)
    2011 F-150 Crew 4X4
    "Hold it to the floor till you see God.... Then Brake!!!!"
    Well that's one thing I forgot to mention. I put another Carb on it. Same issue. I took my otherone apart looked great. Everything was clean and nothing was sticking.
    Well if anyone is interested I got it running. I thing what had happened was the harmonic balancer slipped so my timing mark was off. I timed it to about 14 instead of 12 and it seemed to run just fine.
  5. #5
    Jr. Apprentice meandmyharley61's Avatar
    Sep 2011
    dansville, new york
    I had a 1985 1/2ton, 305 4barrel with three on the tree that had a very similiar problem. replaced the carb a couple of times...no change. I put in another distributor and no more problem. It turns out that the vacumn advance mechanism in the bottom of the distributor was rusted tight. freed it up, put it back in and it ran great. that was just my expeirence. maybe it could affect the timing?
    bill knapp
  6. #6
    The advance is good. I checked it a couple of times. I replaced everything in the dist. Wires and plugs. But its still running good now so I think it was the balancer. Thanks for the post
Similar Threads
  1. Torque Converter Problem?
    By awizore in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 11-19-2011, 12:04 PM
  2. Uh Oh!! .... Torque Converter?
    By ChevyTruck85 in forum GM Powertrain
    Last Post: 05-19-2011, 03:32 AM
  3. 92 C2500 Torque Converter? Please help.
    By TB2K in forum GM Powertrain
    Last Post: 07-03-2010, 08:54 PM
  4. torque converter
    By troysakis in forum Member Introductions
    Last Post: 02-24-2010, 07:24 PM
  5. Transmission or Torque converter?
    By Twistedpinion in forum GM Powertrain
    Last Post: 10-28-2009, 12:48 PM
