    Default Opinion On New Headlight Bulbs
    Got a 1997 GMC Suburban C1500 that I'm upgrading.
    The headlight plastic is no longer clear, so now the intensity of the bulbs is much lower.
    The cost of new plastic is very expensive, but new high wattage bulbs is much less.
    For just a few dollars, I can put offroad 100 watt bulbs for the bright lights in each.
    And, I can put higher wattage bulbs in the regular lights to compensate.
    Does this work very well to overcome the yellowed plastic headlight encasement?
    Brighter bulbs are nice as long as they are legal in your state. You may also want to invest in one of those headlight restoration kits. The kit includes what you need to polish the lenses clear again, and they do work pretty well. I think they usually go for around $20 and will restore a pair of headlight lenses.
    Christopher
    From expericence I have had with high wattage headlight bulbs, they do not like the factory 22 gauge wire and neither does the bulb socket. I Upgraded my headlight harness to 14 gauge wire, and then I put in high temperature 9005/9006 sockets and have been running that setup for 7 years with no problems.
    Also being that you want to use off-road bulbs, they will melt your plastic lenses in a matter of minutes.
    Quote Originally Posted by Tracey121 View Post
    Not as good as replacing them.
    You can buy replacements on ebay for 20.00 each. I've seen complete lens sets (including parking, turning) for under 60.
    Just keep an eye peeled.
    Default Hey if you see that link for 2002 Lights let me know :)
    I'd truly appreciate it, and would like both brighter bulbs and clearer lenses..
    thanks again.
    A friend and I used a cheap (under $25 IIRC) AutoZone headlight restoration kit on a friend's '98 Suburban. It took us about 2 hours (we were thorough, the lights were quite fogged and discolored) from removing the headlights, wet sanding, cleaning and polishing to re-installing and what a difference it made in the quality of the light output from the headlights. Try a headlight restoration kit, I think you'll be satisfied with the results.
    Jr. Engineer McMahan's Avatar
    Jun 2011
    Korea (for now)
    go with DDM tuning or Krypton bulbs HID kit
    2005 Silverado SS
    Color matched AEM CAI,Magnaflow mufflers,cat delete,true dual 2.75" stainless mandrel bent exhaust,Circle D 300K stall,Transgo shift kit,Corvette servos,Detroit Tru-trac,SLP 160* T-stat,Taylor 10.4mm red wires,Comp cams 228R,903 springs,12" cross drilled and slotted rotors,WHEATLEY tuned!!!! Boss 313 22X9.5,Toyo proxes II 305/45/22,
  1. Changing Headlight Bulbs
    By NCN8ive in forum General Chevy & GM Tech Questions
    Last: 07-02-2010, 06:59 PM
  2. Going thru headlight bulbs like crazy
    By sdpbob in forum Chevy Truck Accessories
    Last: 01-18-2010, 02:49 PM
  3. question about new headlight bulbs.....
    By DSpivey in forum Lighting Discussion
    Last: 01-06-2010, 02:08 PM
  4. Headlight Bulbs
    By Cav_spartan in forum General Chevy & GM Tech Questions
    Last: 06-24-2009, 08:05 PM
  5. Halogen Headlight bulbs?
    By jmonte3 in forum Chevy Truck Accessories
    Last: 12-12-2008, 04:25 PM
