    Default Fuse #13 keeps blowing (rear door speakers, cig. lighter, lumbar seat)
    On my 98 Suburban LS, I keep blowing fuse #13, a 20 amp one. This is the one that supplies power to the lumbar seat, the rear door speakers (right and left rear doors - not the back speakers in near the 'barn doors'), cigarette lighter, and the power door locks. Interestingly, I can still operate the power door locks with my key FOB. What happens is that periodically, after maybe a week or so, sometimes longer, sometimes shorter, the fuse just blows. I know that when fuses blow, this means that a power wire gets shorted to ground. So seeing that i rarely use lumbar, I would almost rule that out. Also, the fuse doesn't seem to blow when I operate the power door lock switch on the door itself. Could one of the rear door speaker leads be shorting against metal in the door or possibly in the wire harness between door and frame and after repeated opening and shutting, jars the power wire against a ground? I'm thinking that might be it, only since I sporadically use the rear doors?
    I would check the wiring inside of the rubber boot, that protects the door wiring to the rest of the truck. Or the other possibility is the cigarette lighter wires might be shorting out?
    On my 91 Suburban, the cig lighter outlet likes to blow the fuse it's on which controls interior lights and other things. Look around and maybe disconnect the cig lighters for a week and see if it stops blowing the fuse.
    Christopher
  1. Power locks and cigarette lighter fuse
    By kguygm in forum GM Electrical Tech
    Last Post: 04-07-2014, 05:30 PM
  2. Power door lock/lumbar/rear door speaker electrical gremlin
    By alchemist1 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 11-07-2011, 06:15 PM
  3. cig lighter fuse and door locks
    By morgan44 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 02-10-2009, 05:47 AM
  4. cig lighter fuse and door locks
    Last Post: 01-10-2009, 10:58 PM
  5. 2007 Uplander - cig lighter fuse location ?
    By BigJack in forum Chevy Uplander & GM Minivan Forum
    Last Post: 12-01-2008, 03:05 AM
