    Default noticed a small small coolant leak
    Under the paasenger side front of the engine uneder the cyl. Head
    I really don't want to do a head job but would my 4.3 v6 5 speed swap with a decent v8 cause for me fuel is out the window my engine lost power
    And I think its the valves
    All input would be nice
    murdog94's Avatar
    Sounds like the Head gasket went. and yes a V8 will drop right in im assuming that you are talking about the 95 that your name is? if so then any V-8 (5.0L and 5.7L) will bolt right in from a 1992-1995 with out any trouble.
    Mike
    Currently
    2011 F-150 Crew 4X4
    So even without creamy oil it can still leak?
    murdog94's Avatar
    yep external head gasket leaks are more common in my experience.
    Are you sure it isn't the Intake manifold gasket leaking and running down the seam? I've replaced a lot more intake gaskets than head gaskets on those.
    Good Luck and God Bless
  1. Is a small coolant leak from the intake manifold gasket an "emergency"
    By ross in forum General Chevy & GM Tech Questions
    Last: 05-20-2011, 07:15 AM
  2. small change ...
    By chschevy58 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 03-30-2010, 05:00 PM
  3. Will small cam affect my mpg?
    By cpost562 in forum General Chevy & GM Tech Questions
    Last: 12-29-2009, 10:01 AM
  4. Small Blocks
    By toon5150 in forum Photo & Video Gallery
    Last: 08-10-2009, 11:33 AM
  5. Small lift for 06 Z71
    By CarpenterGuy in forum Chevy Silverado Forum (GMC Sierra)
    Last: 07-19-2008, 10:13 PM
