Page 5 of 5 FirstFirst ... 345
Results 41 to 48 of 48
  1. #41
    If I remember correctly, you cannot and will not get rid of code 12. Code 12 more or less tells you you are in the mode to get codes. The light should be off if all you're getting is 12.
    You would think..... I'm gonna replace the ESS and see if that makes it go away.... I think that's the cause of it since if that's bad the TCM doesn't know the engine is running...
    Joseph
    Airforce Veteran (7 years)
    NRA Life Member
  2. #42
    Well it moved under it's own power for the first time in months today..... It moves.... That's about all I can say at the moment.... I'm pretty sure that ESS I have is bad and that's what won't let it shift more than to 2nd (limp mode)...... It's also throwin a code 24 now too..... I'm gonna hope that one goes away after I get the actual VSS hooked up instead of using the trans rear speed sensor (gotta wire it in)....
    Joseph
    NRA Life Member
  3. #43
    Uh oh......
    Made a Pull-a-part run today...
    But look at the goodies I got :D
    Joseph
    NRA Life Member
  4. #44
    Test drove it again today after swapping the rear trans speed sensor and wiring up the actual VSS..... The service engine light is still staying on (I think it's due to a bad ESS) but it drove fine.... Just lacking TCC operation (which is again due to a bad ESS IMO)..... I pretty sure the speedo is way off right now since the DRAC I have came off a 1500 meaning different tire sizes.... So I need to mod the spare DRAC I got today and see if that takes care of the speedo. All in all a pretty good day...
    Joseph
    NRA Life Member
  5. #45
    Your getting there!
    Everyday I wake up is a great day! ;-)
    05' Chevy Suburban, 11' Ford Fiesta
  6. #46
    Quote Originally Posted by ahm1127 View Post
    Your getting there!
    Yup..... Just need a new ESS and it's drivable again....
    Joseph
    NRA Life Member
  7. #47
    New (used) ESS on the way.
    Joseph
    NRA Life Member
  8. #48
    Got the ESS today and got it installed.... Yay! now I can drive without the Service Engine light on..... Still not sure the TCC is working though.... Might have to replace the temp sensor in the trans.....
    Joseph
    NRA Life Member
    Last Post: 10-19-2011, 07:30 PM
  2. Replies: 0
    Last Post: 01-24-2011, 01:20 AM
    Last Post: 10-30-2010, 08:40 AM
  4. Replies: 0
    Last Post: 11-16-2009, 11:40 AM
  5. Chevrolet : Suburban 2000 Chevy Suburban MONSTER TRUCK FULL CUSTOM
    Last Post: 07-28-2009, 01:00 PM
