Thread: Plugs
    Default Plugs
    Approaching the 90k mark on my '04 Suburban.Looking at changing plugs.Any advice good or bad on which ones to use would be appreciated
    change them and put in AC Delco iridiums. these seem to run poorly with anything else
    good set of wires too, plenty of brands
    David
    1960 Land Rover Series II 88
    2001 Pontiac Sunfire
    NRA Life Member
    X2.....on going with A/C Delco Iridium Tip Spark Plugs.
    Edit:.....if you do go With the A/C Delco Iridium Plugs, they are Gaped right out of the Box, Check the Gap which is set at....0.40.....but Do Not Attempt to Re-Gap them as the Iridium Tip can be Easily Damaged.....
    Caddiac's Avatar
    May 2011
    Upstate South Carolina
    Quote Originally Posted by dsfloyd View Post
    I agree on the plugs but would not change the wires unless their condition warrants the change. Then I would replace them with GM parts. If the insulation shows deterioration, you are having misfires or other reason to suspect the wires are bad then by all means change them. I have not seen the GM wires sold as a factory set. They are sold individually. Mine are 13 years old with 250K on them and they show no signs of needing replacement.
    The plugs are good for at least 100k. If you are like me and monitor your gas mileage at every fill up you could stretch the plugs beyond 100k. Regardless of what you decide to do, when it comes to critical parts, Delco is hart to beat.
    86 911 Porsche Carrera
    98 K1500 Suburban LT
    2012 Nissan Leaf
    ​General Motors.
    Because life is too short to drive a Ford
    I only use AC Delco plugs in my GM gassers....
    Joseph
    Airforce Veteran (7 years)
    NRA Life Member
    I agree with AC Delco Iridium plugs, don't use anything else.
  1. Best Plugs for a 98 4.3
    By Blacksheep1 in forum Maintenance & Upkeep
    Last: 03-28-2011, 12:39 PM
  2. Plugs
    By tbhfrank in forum Chevy Equinox Forum (GMC Terrain)
    Last: 01-19-2009, 09:58 PM
  3. What are these two plugs?
    Last: 10-23-2008, 10:10 AM
  4. NGK plugs?
    By rjevans33 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 09-30-2008, 12:16 AM
  5. Chamion "Truck Plugs" Spark PLugs
    By 4x4_only in forum Performance & Fuel
    Last: 08-12-2008, 08:58 AM
