GM Truck Club
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 24
  1. #11
    Master Mechanic
    lancer's Avatar
    Aug 2009
    Farmersville, Illinois, United States
    315's worked fine on my stock 17's......
    2002 Tahoe LT---------TINTED WINDOWS------------7" DUAL DVD INDASH
  2. #12
    Master Mechanic silverhobey's Avatar
    Oct 2010
    Cobourg, Ontario, Canada
    can you post pics of your upgrade when done ....also,
    let us know the size of both also, as I want to upgrade eventually !!!
    Silverado Crew.....4.8 L
    ---Pendaliner BoxLiner and Side Rails....Van and Truck World
    ---Reese Adjustable Step Down Trailer Hitch....Van and Truck World
    ---PUTCO chrome eyebrow Mirror Covers.... Van and Truck World
    ---PUTCO chrome Bowtie 3rd Brake Light Cover....Van and Truck World
    ---DeeZee TailGate Assist ....Van and Truck World ( now Action Car and Truck Accessories )
    ---Westin Series side steps....Apple Auto Glass
    ---TRIFOLD rear soft Tonneau....Apple Auto Glass
    ---Chevrolet Bowtie Mudflaps...GM Dealer
    ---GM Rear Wheel Well liners...GM Dealer
    ---GM Front Black Tow Hooks w Hloks
    ---GM Chrome Tailgate Handle/matching key-lock....GM Dealer
    ---GM Driver Information Center Upgrade...GM Dealer
    ---GM Front Tinted Bug Deflector...GM Dealer
    ---GM Chrome Door Handles....GM Dealer
    ---Better Built rear hitch step .... Lowe's !!!
    ---AVS Window VentVisors...Canadian Tire
    ---AVS tinted License plate covers....Wal-Mart
  3. #13
    The main thing i've heard from people that run a wide tire on a stock wheel is the tire will tend to buldge out a little on the sides and the truck will walk bad at higher speeds
    2000 Chevy Silverado 4WD Classic
    2'' lift Torsion Keys and air shocks
    33/12.50 Hankook Dynapro M/T
    3 1/2'' down pipe back 6" Tip
    Dodge Towing Mirrors
    Smoked Tails, Cab Lights, and Side Marker Lights
    1% Rear and Side Window, 20% Front Tint
    American Racing Wheels/ With a custom black paint
    Cold Air Intake
    Edge Performance Chip
    Custom Audio System
    LED Tails
    Black background headlights and parking lights
  4. #14
    Master Mechanic Burden33's Avatar
    Mar 2009
    Goose bay, Labrador Canada
    So guys here is an update i ended up getting 315/70 wrangler dura trac and the should be here on the 8 is what ups is saying
    Fabtech/Banks Ram Air |Fuel Off Road/ 315/70/17 duratracs |Hyper tech / Spencershids |
    Color Matched Bowtie |15% Tint on Front Windows|20% Tint on Back Windows
    Chevy Ridin' High
    "Black rims are as cool as a boner at a swim meet"
  5. #15
    Mar 2009
    So guys finally got the tires on the rims and should have them on my truck tmr since i never had time today.
    Click image for larger version.
    Chevy Ridin' High
  6. #16
    very nice. will be nice to see them installed. the biggest thing will be proper air pressure (and not the pressure on the side of the sidewall as that is a max cold psi for full load capacity) or whats on the door panel. there is a pretty easy way to test proper air pressure if you want and then from their you kinda adjust on feel and function.
    David
    2004 Silverado 2500 Crew Cab 4x4, AMSOIL EA air filter, Granatelli MAF sensor, Throttle body spacer, Magnaflow exhaust (true dual to 2 in 1 out muffler), 6" ProComp lift (add a leaf and 5" superlift rear block), Bilstein shocks, 35's (Cooper Disoverer ST) and 4.10 gears, Rhino Liner, EGRUSA fender Flares and widow visors, extended stainless steel brake lines, firestone airbags w/onboard air compressor, Pioneer Avic X940BT navigation, Accel backup camera.
    http://www.gmtruckclub.com/forum/sho...Silverado-2500
    1960 Land Rover Series II 88
    2001 Pontiac Sunfire
    2013 Toyota Avalon Limited (Wife's Car)
    NRA Life Member
  7. #17
    Mar 2009
    So what is the easy way to test it.
    Chevy Ridin' High
  8. #18
    first what is the max cold psi. I know with my 35's it is 50 with a D rated tire. I know some of the duratracs come in E so those are a little different. Either way start with the tire so that it has not been driven for a few hours (as you drive the psi goes up and will give an innacurate initial pressure). I would say with the 1500 start somewhere in the 35-40 psi range (I run 44 on mine but I am a little heavier, I could run the rears a little lower since it is typically empty but its not a big difference. when I tow I fill the rears to the 50 psi max and leave the fronts at 44.). take some chalk and make about a 1-2" wide line across the tread. drive down the street 1/4 mile or so, you shouldnt need to go far and see where the chalk is left on the tread. if the chalk is off the inside and outside edge the tire is underinflated. if the chalk is off the middle and still on the edges it is over inflated. With mine I find I like it best with about 1/2" or so of chalk left on the inside and outside edge. after you check you can make an adjustment. Leave about 10 min in between or if your close make a couple runs. Once you get it to where it wears even there is a range where the wear will be the same within a few pounds and you can adjust according to ride comfort after typical driving and what you prefer. Just remember after you drive the psi will read higher due to the heat so the most accurate is after sitting a few hours if you have been driving. I try to do most of my monthly air checks in the morning before I leave or if the vehicle hasnt been driven in a while. More air will make the tires firmer, less will give a little softer ride within a little bit just depends on how much you notice those things. with mine I have a packed gravel driveway so it works opposite. as I go down the driveway I will pick up dust and look at where it is. so on mine I have just a little bear on the outside and inside edge which seems to work the best for me, since I am also running on a little skinnier rim (8" like you). Its a little bit of a fill and test process but doesnt take too long if your starting point is close. Once you get to that pressure that works for your vehicle its just filling it to that psi when you do occasional checks and filling them up when you load. The scientific way is individual tire scales math and other things wich most of us dont have access or time to do
    David
    NRA Life Member
  9. #19
    Mar 2009
    Thanks for the info ill try that when the rain clears up. Here is a pic of the wheels on the truck
    Chevy Ridin' High
  10. #20
    ^^^^^^that looks so good!!!! I think it looks better than the picture in your sig!
    2006 Duramax LBZ
    Edge Evo
    4'' Diamond eye to 6'' tip
    16'' ion alloy, 33'' fierce attitudes
    Lots of work left to do!
Similar Threads
  1. Biggest tires on stock rims/body?
    By HawaiiKid in forum Chevy Truck Accessories
    Last Post: 12-17-2010, 11:31 PM
  2. Will 16x8 rims fit stock tires?
    By jordanr1987 in forum Wheels & Tires
    Last Post: 09-27-2010, 11:39 AM
  3. Over sized tires on stock rims
    By FosgateElite in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 04-19-2009, 10:08 PM
  4. FS: Stock Silverado Rims and Tires 18K NJ
    By ataririder in forum General Classifieds
    Last Post: 04-14-2008, 10:37 AM
  5. Stock Chrome Silverado Rims and Tires
    By steingang2 in forum General Classifieds
    Last Post: 06-08-2007, 03:33 PM
