    Default 1997 Tahoe weird Headlight switch issue
    I've just searched through almost 500 posts on headlights and either this hasn't come up or I missed a thread. I have an issue where when I turn my headlights on, the headlights don't light up but I have tail lights. When I turn the switch to the parking lights position, I have head and tail lights, but cannot activate the brights. So I figured bad headlight switch...no big deal. Got the new switch today, did the replacement and still the same problem.
    Any ideas where I go from here?
    Thanks in advance
    Sounds like the DRL lights are what you're seeing when the parking lights are on. Check the headlight fuses, or all the fuses for that matter, I'm not sure if they are on a seperate fuse or not. If I recall the headlight has an actual fuse apart from the DRL fuse.
    I would also double check the harness going to the switch. Mainly check the pins inside the housing. It's been a while since I've had one of those out but if it's got a connecter housing with a shell around it, it's possible that one of the pins may be be fried inside. It's common on older Ford alternator connectors and I've also seen it on a few Fullsize Chevy a/c blower motor switch connectors. You could also check that same connector for power coming out when the switch is plugged in. If the diagnosis has to go further, post up and I'll chime in with more thoughts ...
    Thanks for the suggestions. I haven't had time to look further, so I'll check this out this weekend.
    A faulty dimmer switch will cause your problem. Unfortunately, you have to replace the entire "multi-function" switch if it's bad. Take a good, hard look at that connector, too.
    Good Luck and God Bless
    This weekend I went through and checked all of the fuses, looked at the wiring harness for any burn or scorch marks, used the volt meter to see if I was getting voltage and continuity to the headlight switch and all checked out OK. I'm thinking it is the dimmer switch. So later this month I'll head to the local Pull-A-Part and retrieve a dimmer switch to try.
    BTW, any instructions on how to remove the dimmer switch. I started yesterday, but couldn't spend a lot of time on it. There were 2 torx bolts on the bottom of the steering wheel, so I removed those, but didn't see what else I needed to remove.
    Found the problem...it was the multifuntion dimmer switch. I went to the local 'Pull-A-Part' and found the switch I needed and paid only $9 (woot woot), and just finished putting it in. What a pain in the rumpus, but I now have headlights that I can control.
    My biggest obstacle was getting the bottom T-25 torx bolt out. I had to use a 1/4" box wrench and a T-25 bit. It was slow but worked.
    Congrats on the repair!
    1999 Chevy K2500 Suburban 350
  1. Headlight Switch Issue....
    By sstoner911 in forum GM Electrical Tech
    Last Post: 08-18-2011, 07:58 PM
  2. Tahoe silverado 1995 1996 1997 blower fan speed switch
    Last Post: 07-02-2011, 11:20 PM
  3. Tahoe silverado 1995 1996 1997 blower fan speed switch
    Last Post: 06-06-2011, 01:40 PM
  4. Tahoe silverado 1995 1996 1997 blower fan speed switch
    Last Post: 04-09-2011, 11:20 PM
  5. Brake light switch issue. 97 Tahoe
    By Scott77 in forum GM Electrical Tech
    Last Post: 09-27-2010, 07:30 AM
