    Default 1995 silverado run like crap !
    my 1995 silverado run bad it rolls over a long time before it starts and if you try to get on it, its like its starving for gas . changed the fuil filter but didnt help. need help bad thanx!!!! if the truck starts running bad i can shut it off and it will run better for a wile.
    Welcome to the club. Is the check engine light on? Maybe the cat is plugged. '95 and older trucks don't have a rear O2 sensor to check the cat.
    :cool:
    Weather Tech floor mats
    Cover-Craft seat covers
    Dash mat cover
    Formula One window tint
    One black Lab in rear seat.
    :glasses:
    Apr 2011
    Lumberton, TX
    Could be as simple as a clogged air filter. Assuming it is good, do you smell gas in the exhaust or anything? Does it only start slow after it has been sitting for a while or every time you start it? Does it idle rough?
    no cat on truck and no check engine light and it idles fine and dont smell gas in the exhust.
    Newbie
    May 2009
    Destrehan, La.
    You could be losing fuel psi i have a fuel pump that was sucking air in the tank the fuel line hose between the pump and the metal line. Also check the wiring at the pump they will miss upand short out
    Apr 2011
    Lumberton, TX
    That could also be an injector issue or a bad gas issue. run some sea foam through and see if you get any change. With gas prices being the way they are, it is easy to get bad gas cause it's cheap. And it's not just us doing it, the stores are buying the cheapest gas they can get too.
    Newbie
    May 2009
    Destrehan, La.
    there are a few things that will make it run like that throttle position sensor, the IAS, crank sensor, O2 sensors, fuel injectors, also check the wiring between map sensor and the throttle position sensor. i have a 90' and 92' that had the same problem.
    Default thanx for the replys
    I replaced the fuilpump assembly and it fixed it all !!
  1. What is the BEST way to get this crap off?
    By Jimmeh in forum General Chevy & GM Tech Questions
    Last: 04-26-2011, 06:01 PM
  2. Holy crap!
    By z3ro in forum The Coffee Shop ~ Chit Chat
    Last: 03-22-2010, 08:24 AM
  3. crap!
    By capt sensible in forum Audio, Video & Gadget Tech
    Last: 09-26-2009, 06:48 PM
  4. Crap Tranny
    By sonomanick in forum Chevy S10 Forum (GMC Sonoma)
    Last: 07-21-2009, 10:04 PM
  5. Funny crap
    By Cableguy in forum Photo & Video Gallery
    Last: 12-18-2007, 09:05 PM
