Results 1 to 2 of 2
    Default 99 2wd suburban with Sarona body kit ground clearance issue!!!Please help new member
    Hi,
    I am a new member, was searching on the net and called at summitracing for some options
    to lift my 1999 2wd C1500 chevy suburban. I have installed a Sarona body kit, and I am having a huge
    ground clearance issue now. I only have 3 inch of clearance between the lowest trim of the front bumper and the ground!
    I know that there are body lift kit and suspension lift kit.
    I would like to know wich one is the more cost effective? Some suppliers says that over 3 inch you need a upper control arms lift kit and
    new shocks. Some others says the same thing after 2.5 inch lift!?
    Then, how much ground clearance should I need to stop rubbing the bumper? I measure my camaro front lip to the ground and it's about
    7 inch? With that said, would I need a 4 inch lift to get the same ground clearance of my camaro???
    I am in a hurry to do the lift because I want to store my truck in my garage for the winter and I can't even bring it in my driveway...
    Any help would be really appreciated!
    Thanks in advance,
    Patrick
    Sr. Engineer ahm1127's Avatar
    Pennsylvania, United States
    Your not offroading it so a body lift will be fine, just make sure all body bushings are in good shape. You will be able to fit bigger tires under truck wich will also make the truck higher.
    Good luck
    Everyday I wake up is a great day! ;-)
    05' Chevy Suburban, 11' Ford Fiesta
  1. tire clearance? level and body lift.
    By chase87 in forum Wheels & Tires
    Last: 08-09-2011, 10:22 AM
  2. Ground issue? Antifreeze Has Voltage-- help!!
    By cmobile in forum General Chevy & GM Tech Questions
    Last: 01-09-2011, 07:41 PM
  3. Ground Clearance 2009 Sub
    By Room 055 in forum Lifted & Offroad Suspension
    Last: 03-29-2010, 10:33 AM
  4. 98 Suburban- bad ground, iffy starting
    Last: 06-29-2009, 09:59 AM
  5. clearance issue?
    By 9915hundred in forum Performance & Fuel
    Last: 06-25-2008, 09:47 AM
