    Master Mechanic Burden33's Avatar
    Mar 2009
    Goose bay, Labrador Canada
    Default second battery and advice on amps
    so guys im about to tackle my stereo system and im looking at adding a second batter to my truck for stereo and was wondering how do i hook it up. now for second question is i just got my alpine SWR -t12 with 600watts rms and was wondering if these amp will run it or will it be under/too much power for the sub http://www.alpine-usa.com/product/view/mrx-m100/default
    Fabtech/Banks Ram Air |Fuel Off Road/ 315/70/17 duratracs |Hyper tech / Spencershids |
    Color Matched Bowtie |15% Tint on Front Windows|20% Tint on Back Windows
    Chevy Ridin' High
    How you connect a second battery will depend entirely on your application. You can go 24 volt, you can isolate one, or you can isolate them both (from each other). Each has its uses/purpose, strengths and weaknesses.
    May 2010
    Ft.Worth,TX
    I have done this two different ways,first with a continuos(sic) duty solenoid,this has the problem of boiling one battery while charging the low battery,second I have used an old regulator housing and two diodes,this has the same charging problem it just not drain both batteries.I have user this forum to search about this.I do not know if isolators will take care of charging or not.I could not find if they separate the charging or not.Seems to me the best way is to use two alternators,used on some diesels,this totally separates the batteries.A little more work,but foolproof.You may need an upgrade on your alternator if you go with first two ways.Good luck and happy truckin.
    2008,2500 silverado,k-n filter,flowmaster 7o series muff. linex bedliner.
    Quote Originally Posted by Burden33 View Post
    If you run the subs at 4 ohm you get 600w which should be fine for the subs.
    as for the second battery - Why a second battery? With what your running the only reason to run a second battery would be if you run the system with the truck off for extended periods of time...which you would run an isolator to always maintain a charged battery if one is drained or fails etc...
    Get the Gorilla!
    gorilladip.com
    sales@gorilladip.com
    Mar 2009
    i was planning on running another sub with the pdx-m12 amp which would be 1200 watts rms it just seems like alot on the one battery. do anyone know what the difference is in a dual down fire box and an up fire box and is it better to have the box sealed or ported
    I am running 2 amps - 1200 watts @ 1ohm and 4 channel @ 100watts per channel on one battery. The guys running competition setups with 6-12 amps usually run multiple batteries.....but having a dual battery system doesnt hurt anything if thats the route you want to go.
    Down fire boxes are where the subs are facing down on the botton of the box....upfire are your installed in the top of the box facing up.
    Sealed boxes give a sharper clean bass response(quicker)....ported boxes generally go lower in range and give the "BOOM" factor.
    Mar 2009
    im also looking at running a capacitor instead of a second battery just wondering what good ones are out there
    Mar 2009
    So guys im going to run a second battery and do the big 3 instead of ruunong a capcitor
    Sounds like a good plan.
    Caps are Bandaids and a waste of money OR how Best Buy makes there money.. Do 2 Good Batt's and maybe a good Alt and you will be fine..
  1. Who knows about speakers, amps, etc?
    By Breathtaker in forum Audio, Video & Gadget Tech
    Last: 06-26-2014, 10:03 AM
  2. how many amps is my alternator
    By bud82067 in forum Chevy C/K Truck Forum
    Last: 11-15-2011, 05:48 PM
    Last: 11-28-2010, 07:46 AM
  4. amps wattage
    By Burden33 in forum Audio, Video & Gadget Tech
    Last: 07-16-2009, 04:08 PM
  5. where to put the amps?
    By collinsperformance in forum Audio, Video & Gadget Tech
    Last: 02-05-2008, 06:00 PM
