    Default Need help identifying 99 suburban front differential
ID:	31989Click image for larger version.
ID:	31990Click image for larger version.
    The picture on left is the one the salvage yard says is supposed to be in my truck according to build code. The middle picture is of the front Diff I just removed. The one on the right has both picture with arrows pointing to the differences.
    Build code says GT4 which is 373 ratio. Got used one from salvage yard and they claim it should match my build code however it is different. My unit only has one plug for the motor that switches the front diff but the replacement one has 2 plugs. One to a motor housing and the other to something that looks like a sensor. Of some sort. Any help in identifying would be appreciated. They are definately different.
    Default Help a brother out. Anyone?
    Can anyone help
    One out of your truck is a 8.25" IFS front differential. I just rebuilt mine out of my 2002 silverado, has exact same connection. You can screw off the plastic actuator on the one on your truck. I would stick with one that is from your truck. What is wrong with yours?
    www.youtube.com/ippielb
    Thank you so much for the reply.
    My front diff is making a low grinding noise. Not real bad but you can hear it while slowing down from 50 mph and less.
    I'm planning a 700 mile trip each way back to Maryland and wanted to fix it before I left.
    If I can tell the salvage yard what I need I'm sure they can get it for me. I was just trying to confirm the following I guess:
    1. Is the one removed from my suburban the original front diff or was it swapped before I bought it to a newer one.
    2. Is the salvage yard wrong and what they gave me is not intended for a 1999 suburban?
    3. Assuming both above are correct then maybe I need to ask for a front differential for a later model silver?
    4. Rebuilding an option. I have a guy that can help me crack my old case open and see if it's just som bearings that we can replace.
    I really need to find a 1999 suburban in a parking lot and craw under for a look at someone elses.
    The question is do all 1999 k1500 suburbans have a front diff with one plug or do they have 2 plugs.
    Thanks
    Quote Originally Posted by Johndavidrichards View Post
    The one you removed is the original.
    Yes, I believe the one the that the wrecker supplied you with is from a 1998 body style suburban.
    You can ask for a front differential from 99-06 that has the same gear ratio as your suburban, i would recommend going 04+ as they have fixed a breather line problem and you can use synthetic fluids.
    You can easily crack open your case yourself! Since you have it off already you've gotten half the battle done! Drain the fluid, and then just unbolt the two halves together, and convince the two halves to separate.
    To my knowledge the 99+ all have the one plug.
    My replies in RED.
    Here's my differential from my 2002 silverado
    In all reality, this is what could be causing a humming or grinding, or if your gears are not set up properly, one of the locking tabs could have broken and set the backlash off and set the pattern crazy.
    I also had a bad bearing or two. Be sure to get your fluids changed!
  1. Identifying 86 K2500 Suburban brakes.
    By Geoffr in forum Lifted & Offroad Suspension
    Last: 04-23-2010, 08:31 PM
  2. front Differential
    By jacobus in forum Member Introductions
    Last: 01-03-2010, 08:46 AM
  3. What front differential in 06' 1/2 ton?
    By gocubs68 in forum GM Powertrain
    Last: 05-30-2009, 09:06 AM
  4. GMC C3 Front Differential
    By Soldier-Services in forum GM Powertrain
    Last: 02-18-2009, 01:50 PM
  5. front differential leaking!!
    By fierodough in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 06-26-2007, 11:01 AM
