    Exclamation 98 Chevy 1500 5.0 Wont Start Cold
    I have a 1998 Chevy Silverado 1500 5.0 305 4x4. When i sits overnight or for a long time it will turn over fine but will not fire up. changed plugs, wires, starter, battery, battery cable to starter. Turns over just fine and fuel pump sounds healthy but will not fire up and run, UNTIL i put jumper cables on it and fires right up....??? and after i drive it and it warms up i can turn it off and start it just fine
    already did
    ---------- Post added at 01:09 PM ---------- Previous post was at 12:58 PM ----------
    could it be fuel pump? people are tellin me that but i dont think so cause why would jumper cables make it start
    Welcome to the club, Derek. Have you checked your fuel pressure? If the fuel pressure drops it will be hard to start until the f/p builds up. Maybe by the time you jump it the f/p has built up enough to start the truck. Does this happen after the truck has sat for awhile like overnight?
    :cool:
    Weather Tech floor mats
    Cover-Craft seat covers
    Dash mat cover
    Formula One window tint
    One black Lab in rear seat.
    :glasses:
    Check ur grounds and ur fuel pressure. Try turning the key to run and let it sit there for 10-15 seconds then crank it. If it fires up you need a fuel pump. Also check the vacuum on your fuel pressure regulator
    Redneck Rucker
  1. 02 Silverado 1500 wont start occasionally
    By charriman in forum General Chevy & GM Tech Questions
    Last: 09-25-2011, 06:17 PM
  2. No Luck 2001 1500 cold start problem.
    By bill.turner3 in forum General Chevy & GM Tech Questions
    Last: 11-23-2010, 09:01 PM
  3. 1991 Chevy 1500 4x4--WONT START! And will die
    By WhiteZ in forum Chevy Truck Tech Forum
    Last: 07-23-2010, 06:35 AM
  4. 96 Silverado 5.0 wont start when cold out.
    By chris731 in forum GM Powertrain
    Last: 03-14-2010, 09:07 AM
  5. 1997 Silerado ....5.7 vortec . Wont start when cold
    By qpe05 in forum GM Powertrain
    Last: 09-05-2007, 03:22 PM
