Results 1 to 2 of 2
    Default 08 Sivlerado Ball Joint upper control arm?
    Ok have an 08 Silverado 4x4, swapped out from shocks/struts with the bilstein 5100 adjustable, have the truck leveled out. Bought new tires around 8000 miles ago or so, the front outside edge of the tires is getting worn, have had them rotated and balanced, took the truck in to have alignment checked and the driver side upper balljoint is worn out with 37K miles on it. Thinking this is worn prematurely from a wreck back when i first got the truck, but shop said thats why tires are wearing wrong, but upper ball joint cant be replaced, have to get a new upper control arm........is this correct? if it is true, should i just get aftermarket ones that are designed for the change in suspension up front, or stick with the stock oem upper control arms. THey quoted me like 238.99 for stock upper control arm, 158 buck s in labor and 80 bucks for he alignment. seems steep for the upper arms? any thoughts.
    Other thing is.....will my extended warranty cover the ball joint?
    2008 Silverado LTZ Crew 4x4 5.3L
    Stock 20 w/ Cooper Zeon LTZ 33's
    Navigation
    DVD
    HD Trailering
    Alumiknox Black Truck Box
    Bilstein 5100's Leveling Shocks
    if you only have 38k miles on it a dealer should fix it for free. Generally they call it a "goodwill" repair. I just had them replace a leather passenger seat and a few other things on my wife's torrent, it has 55k and they did it free. I would not tell them about your accident.
  1. upper and lower ball joint replacement 1997 chevy k1500
    By karroe in forum Chevy C/K Truck Forum
    Last: 03-01-2012, 11:58 PM
  2. Ball joints and upper control arm
    By Stonewall42 in forum Lifted & Offroad Suspension
    Last: 06-02-2011, 07:36 PM
  3. control arm/ upper ball joint
    By bleebs in forum Lifted & Offroad Suspension
    Last: 05-02-2011, 03:48 PM
  4. 4 Ball Joint Lower Upper Chevy Silverado 1500 2WD 99-04
    Last: 03-25-2010, 06:00 PM
  5. Upper Knuckle Ball-Joint Replacement
    By GlitchMobile in forum How-to Guides
    Last: 11-13-2008, 03:32 PM
