    Default CV Joint Question
    Do the CV joints rotate when not in 4wd? My concern is i have a squeaking noise under my truck have not been able to locate it. I have put it on a lift run it in both 2wd and 4wd and it wont do it. The sound is almost like a U-joint but i know that is not it but it has a similar sound. Any ideas what it could be?
    2000 Chevy Silverado 4WD Classic
    2'' lift Torsion Keys and air shocks
    33/12.50 Hankook Dynapro M/T
    3 1/2'' down pipe back 6" Tip
    Dodge Towing Mirrors
    Smoked Tails, Cab Lights, and Side Marker Lights
    1% Rear and Side Window, 20% Front Tint
    American Racing Wheels/ With a custom black paint
    Cold Air Intake
    Edge Performance Chip
    Custom Audio System
    LED Tails
    Black background headlights and parking lights
    Assuming this is the 2000 in your signature, yes, the CV axles will turn with the wheels in 2wd.
    If the noise goes away on a lift, I might suspect something suspension related (a noisy bushing or a loose bolt or similar).
    CV rubber..or bushing, i had a shock even drive me nutz once !
    OH, and like above said already..YES they turn !
    Scott:glasses:
    Ok i will check that out.It is a 2000 classic old body style if that changes anything?
    This might sound very odd but the noise doesn't happen until it rains and whatever gets wet then it makes noise. It has not done it for the last 6 months and we haven't had a drop and now we got like 3'' and the noise is loud as ever. I know it sounds weird but that 's what it does.
    Spray some SILICON SPRAY on the rubber of the CV axles and see if that changes anything !!!
  1. Question after replacing upper ball joint on control arm
    By sstoner911 in forum Lifted & Offroad Suspension
    Last: 11-25-2011, 07:17 PM
  2. 1997 Chevy K1500 Pick Up lower ball joint question
    By bizguy in forum General Chevy & GM Tech Questions
    Last: 11-17-2011, 08:06 AM
  3. U Joint Help
    By Rhyno37 in forum General Chevy & GM Tech Questions
    Last: 06-28-2011, 10:06 PM
  4. U Joint going bad?
    By BenEllis in forum Chevy Silverado Forum (GMC Sierra)
    Last: 06-17-2010, 01:27 AM
  5. Howdy Folks! U-Joint question...
    By m0j0TX in forum GM Powertrain
    Last: 06-18-2009, 07:50 AM
