    Jun 2009
    sioux city, Iowa
    Default best proven exhaust
    My exhaust is finally getting to the point where I'm going to have to replace it. It currently has 3 inch true duals with stock cats with 2 aftermarket mufflers (can't remember what brand, they are stainless though). What's the consensus on exhaust now that the 5.3 has been around for a while? is single with a good muffler the way to go or is 2.5 inch dual? I know 3 inch is definitely too big for a stock 5.3
    93 trans am-FOR SALE!
    87 Buick Turbo-T WE4 Yes, they are fast:he:
    I have a corsa system on mine. It sounds ok, not too loud, and does not drone at highway speeds.
    I have corsa as well on my 2010. No drone inside the cab. Well worth the money
    Jr. Engineer McMahan's Avatar
    Jun 2011
    Korea (for now)
    I have magnaflow mufflers on mine with cat delete and absolutly love it
    2005 Silverado SS
    Color matched AEM CAI,Magnaflow mufflers,cat delete,true dual 2.75" stainless mandrel bent exhaust,Circle D 300K stall,Transgo shift kit,Corvette servos,Detroit Tru-trac,SLP 160* T-stat,Taylor 10.4mm red wires,Comp cams 228R,903 springs,12" cross drilled and slotted rotors,WHEATLEY tuned!!!! Boss 313 22X9.5,Toyo proxes II 305/45/22,
    From my experience and what i have seen I am huge fan of split 45 degree duals, My problem with straight duals is that if not done correctly or poor product then they will become un even. on My 2010 silverado 1500 5.3l I have the sport dual from MBRP sounds great no drone, and looks great.
    I got mine from Little Power shop out of PA. They are pretty good.
    Now my Brother has Flowmasters on his 2005 5.3, sounds good but loud too and alot of cab drone.
    Hope that helps.good luck
    I have the MBRP Performance Catback and I love it, nice sound at idle and really opens up when you step on the pedal. Not a bad price either. Angles out behind the rear tires.
    2003 Silverado 2500HD 6.0L Vortec V8
    2" Body Lift
    3" Suspension Lift
    Skyjacker Hydro 7000 Shocks
    Skyjacker Steering Stabilizer
    35" Tires with 20" American Racing Rims
    Velocity Cold Air Intake
    Billet Throttle Body Spacer
    BBK Performance Headers
    MBRP Cat-Back Exhaust System
    DiabloSport Predator- Soon to be tuned by Diablew
    "Soon to be leveling-kit"
    Jun 2009
    sioux city, Iowa
    I'm not looking for particular brand, more which style than anything. Is there any gain from going from single to dual? Is there anyone running 3inch single with a performance muffler?
    You could go with a 2.5in pipe and a 3in tip. I think a true 3in pipe all the way out is to big for a 5.3 you lose back pressure. ive got a true straight pipe(no cats) that runs to a flowmaster super 44 and it sounds great. It is a little loud on the highway but i dont take the highway that much anyways.
    Redneck Rucker
  1. Exhaust specifications. THIS IS NOT ANOTHER WHICH EXHAUST SOUNDS BETTER THREAD!
    By Farmerdave in forum General Chevy & GM Tech Questions
    Last Post: 09-28-2010, 04:49 PM
  2. CGS intakes/exhaust & MBRP exhaust
    By PIKE33 in forum Performance & Fuel
    Last Post: 06-26-2010, 11:38 AM
  3. Exhaust ideas for 2003 GMC Sierra - Dual Exhaust
    By RyGuyGMC in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 03-16-2010, 09:39 AM
  4. Exhaust?
    By Tapper1823 in forum Performance & Fuel
    Last Post: 09-26-2008, 08:10 PM
  5. Exhaust help - True Dual Exhaust Possible???
    By Jordan in forum Performance & Fuel
    Last Post: 06-25-2008, 10:27 AM
