GM Truck Club
Page 2 of 4 FirstFirst 1234 Last Post byLast Post by
Results 11 to 20 of 32
Thread: Strange Noise
  1. #11
    Had the same problem on an 08 Silverado after I put a bug shield on. It was comming from the side windshield moldings. Had to put double sided tape to stop it. The GM supplier of the bug shields knows of this problem and instructs the use of tape.
    Ken
  2. #12
    Sr. Apprentice Silver Chevy's Avatar
    Jul 2011
    Long Island New York
    Hey sorry guys ,,, bug sheild,, wippers, will come off tomorrow and will see
    Modís.. 8,000k Hid Head Lights and Fog Lights, 6 1/2 Infinity Reference 6030cs in the front. Infinity Reference 6032si 6-3/4 in rear,, Front and Rear powered with Sound Ordnance M-4100.
    Custom Sub box with 2 10 inch Kicker 10CVR104 with a JL Audio JX360/2 2-channel amp.
    Painted door Handles, Mirrors, and Wheel Well Moldings, Tinted Front windows, Custom Pinstripe,
    20 inch Enkei GRAB6 with a set of Bridgestone Dueler H/L Alenza tires.
    Gibson Dual Exhaust, K&N cold air Intake.
  3. #13
    Exclamation I have the noise toooooooooooooooooo
    ................I have a bug shield and that annoying noise too above 60-65mph. I just got my truck and it drove me nuts on way to work this morning. Let me know what your tests reveal. If it gets ride of the noise I'll be happy to trash bug guard or sell on Craigslist.
    Thanks,
    Audible
    2011 1500 Silverado LT, 4x4/Z71
    K&N, Chrome Nerfs, Run Lucas Oil fuel treatment,
    DB-CORSA cat-back system (received). :great:
  4. #14
    The way I did it was to put electrical tape between the rubber gasket and the wind shield to see if it solved the problem. The test worked so I taped it.
  5. #15
    Been doing some research on this topic and I've found a fix! Looks like there is actually a service bulletin related to this.
    TECHNICAL
    Bulletin No.: 08-08-48-003F
    Date: April 06, 2011
    Subject: Tapping, Clicking or Ticking Noise at Windshield Area (R&R Right and Left Windshield Side Reveal Moldings to Add Double Sided Tape)
    Models:
    2007-2012 Cadillac Escalade, Escalade ESV, Escalade EXT
    2007-2012 Chevrolet Avalanche, Silverado, Suburban, Tahoe
    2007-2012 GMC Sierra, Sierra Denali, Yukon, Yukon XL, Yukon Denali, Yukon Denali XLSupercede:
    This bulletin is being revised to add model years. Please discard Corporate Bulletin Number 08-08-48-003E (Section 08 - Body and Accessories).Condition
    Some customers may comment on hearing a tapping, clicking or ticking noise at the windshield area. This condition occurs more frequently while driving at highway speeds and could be exaggerated on vehicles with front bug guard deflectors.
    Cause
    This condition may be caused by air/wind causing the windshield side reveal moldings to move, generating a noise.
    Correction
    Remove both windshield reveal moldings, add double-sided tape and re-install the moldings following the steps below:
    1. Using tape (1) or a grease pencil, mark the position of the inboard edge (2) of both left and right reveal moldings onto the windshield, following the contour of the molding.
    2. Remove the left and right windshield side reveal moldings. Refer to Windshield Side Reveal Molding Replacement in SI.
    3. Being careful not to affect the tape or grease pencil marks, clean and prep the glass at the seal interface with Glass Adhesion Promoter, P/N 12378555 (in Canada, use 88901239).
    4. Apply 3M Automotive Adhesion Promoter 06396, or equivalent, to the underside of the reveal molding seals.
    Tip
    An approximate 600 mm (24 in) length of tape should allow for overlap at the top to be trimmed back leaving a tail of release liner (1) and, at minimum, should reach the fender cut line at the bottom.
    5. Apply a 600 mm (24 in) length of 3M Automotive Acrylic Plus Attachment Tape 06386 (1.14 mm (0.045 in) thick x 6.35 mm (0.25 in) wide), or equivalent, to both sides of the windshield. Ensure the tape (1) position is centered between the windshield edge (2) and the tape/grease pencil line (3). Do not remove the release lining from the tape yet.
    6. Reinstall the reveal molding to one side by sliding the molding downward and ensuring that the top lip is engaged at the upper edge of the windshield.
    7. Install the fasteners to the reveal molding, starting from the top. Refer to Windshield Side Reveal Molding Replacement in SI.
    8. Lifting the top edge of the reveal molding, grab the tail of the release lining and pull downward removing the lining.
    9. Press or roll the reveal molding against the windshield ensuring adhesion of the tape to the glass.
    10. Repeat steps 6-9 on the opposite side.
    11. Remove tape or clean the grease pencil marks from the windshield.
    12. If positioned correctly, trimming of the double sided tape should not be necessary, however inspect the reveal moldings for any tape not covered and trim off any exposed tape.
    Important
    After taping the windshield reveal moldings, avoid washing the vehicle as well as excessive contact with the windshield reveal moldings for a minimum of 72 hours.Parts Information
    3M(TM) products may be purchased through your local distributor. Information about 3M product retailers in your area may be obtained by calling 1-866-364-3577 (U.S. and Canada).
    Jeff - Connecticut
    2011 Silverado LT Z71, 5.3L, Towing Pkg
  6. #16
    Morning.................any change or new information for us?? Thanks
    Quote Originally Posted by Silver Chevy View Post
  7. #17
    Bump...anyone? The noise is annoying on a $30k truck.
  8. #18
    Jr. Apprentice
    Dec 2011
    20 mile north of Pittsburgh
    I agree with the bug sheild had a brand new 99 made the same kind of noise remove bug sheild noise went away
  9. #19
    Jul 2011
    No change so far still working on it,, I'm going to tape the top of the windshield
  10. #20
    Jul 2011
    I taped the top of the windsheild noise is going,, so off to the dealer on Monday,,,, son of a bitch,, I can't believe it
    ---------- Post added at 05:39 PM ---------- Previous post was at 05:35 PM ----------
    I taped the winshield and sure enuff no noise,, so off to the dealer on Monday,,, I also have Tire sensor that 10lbs off ,,,, always something
Similar Threads
  1. Lifted 94 Z71 Strange Noise
    By pondfishr in forum GM Powertrain
    Last: 02-03-2011, 11:05 PM
  2. Strange noise coming from A/C ! Please help
    By CHEVY2G in forum GM Powertrain
    Last: 02-02-2011, 10:44 AM
  3. HELP - Strange Noise
    By CJM in forum General Chevy & GM Tech Questions
    Last: 04-25-2010, 06:59 AM
  4. strange noise
    By deckboat234 in forum General Chevy & GM Tech Questions
    Last: 03-04-2010, 03:32 PM
  5. Strange noise under the hood
    By jediracer in forum GM Powertrain
    Last: 07-08-2009, 10:17 PM
