Results 1 to 2 of 2
    Default oil pressure low
    I have recently acquired a 2003 Silverado LS extended cab. The oil gauge jumps from zero to as far right as it can go and everywhere in between. When it is jumping all over the place, the oil pressure low displays as well. The volt meter stays on zero and the battery is new.
    The service engine light also stays on. I had the oil/filter but that did not solve the issue. Helpful information needed.......
    Quote Originally Posted by Reddog View Post
    With the Service Engine light coming on........you should have the truck scan to see what causing the SEL to come and stay on??......your local auto parts outlet like.....Auto Zone....O'Reilly's....etc will do this at no charge.......and for the 2 gauges the problem maybe with the stepper motor's for each gauge is going Out/Bad and maybe need to be replaced..........which is a Common Problem with the 2003" to 2005" Truck/SUV's Dash Clusters.
  1. Oil pressure
    By 1991 Suburban in forum General Chevy & GM Tech Questions
    Last: 03-11-2011, 02:13 PM
  2. oil pressure?
    By 2wheelmudder in forum General Chevy & GM Tech Questions
    Last: 05-19-2010, 01:44 AM
  3. Oil Pressure
    By Lightzz2k in forum Chevy C/K Truck Forum
    Last: 06-29-2009, 09:23 PM
  4. Oil Pressure changes
    By GiS in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 06-10-2009, 03:13 PM
  5. low oil pressure
    By jackofallammo in forum GM Powertrain
    Last: 04-13-2009, 09:36 AM
