Results 1 to 10 of 11
Thread: air-bag light
    Default air-bag light
    The airbag light stays on after start-up. It blinks at 1st then a steady on. The passenger light says off. 2006 1500 express.
    Any ideals where to start looking. I checked the fuse and it was good.
    Check the wiring that is on the floor by the driver's feet. That can become worn and short out. Look for it at the left kick panel and work your way to the fuse block.
    Quote Originally Posted by papher51 View Post
    The best way to diagnose your issue is to find someone with a scan tool that can read air bag or sir codes. It could be a bad impact sensor. I had one go out on my truck and the same thing happened. My airbag light has been turning on in extremely cold weather. It will turn on and off randomly during a long trip. I an betting that it is a failing sensor, I just have not had it scanned.
    I forgot to mention that I had replaced the radio about the time the srs light started staying on. Would that have anything to do with it?
    did you pull the seat or anything to get at the fuse block? Did you remember to plug the airbag seat sensor back in? Just a though,
    Brew
    I checked the connector under the seat. It was fine. Thanks
    I had the same problem on my suburban, I pulled the carpet back to the left of the brake pedal and jiggled the wires and magically it went off. Like someone else said on this thread it could be a short or just came loose.
    I checked all of the wiring under the floor mat and under the seat. It was all good.
    Then I would say your next move is to take to someone who can read the codes and see what it says.
    Quote Originally Posted by tsbrewers View Post
    again, I am betting it is an impact sensor, you have to have it scanned.
