11-25-2011, 09:31 PM #1
Data gathering for regearing -- some assistance?
Here's what I know:
- Year, Make, & Model: 2004 GMC Sierra 1500 Ext Cab 4x4 w/ 96" Bed
- Tire size: 315/70R17
- Original Gear Ratio: 3.73 (RPO Code GT4 = Axle Rear (DUP WITH 5 X 1) 3.73)
- Desired Gear Ratio: 4.56
- Number of Cover Bolts: 10 bolt (11 inches wide - i.e. has GM 8.2 or 8.5 ring gear diameter, but not sure which)
- Transmission Type: 4L60E
- Engine Size: 5.3L
- Desired Highway Cruise Engine RPM: ~2000
- Number of Wheel Lugs: 6
- Suspension Type: Independent Front
Here's what I need to know (ideally without any disassembly, as I'm merely information gathering in order to cost out parts) and don't know how to find out:
- Axle spline Count?
- Actual Ring Gear Diameter (8.2" or 8.5")?
- Number of Ring Gear Bolts?
- Dana Bill of Material Number or Tag Numbers (if applicable)?
- Standard or Reverse Rotation Front Ring & Pinion?
- Axle Bearing Outer Diameter?
2004 GMC Sierra 1500 5.3L V8 4x4 SLT Extended Cab Long Bed
(Garage Link: http://www.gmtruckclub.com/forum/sho...MC-Sierra-1500)
NRA Certified Instructor, Range Safety Officer, & Benefactor Member
"I have sworn upon the altar of God eternal hostility against every form of tyranny over the mind of man." -- Thomas Jefferson
"The only difference between the topic police and the thought police ... is spelling." -- Anonymous
11-26-2011, 09:44 PM #2
This data is what needs to be collected prior to ordering parts for regearing. Colour me VERY surprised that we have so many people who have regeared ... and no one ordered his/her own parts.
11-27-2011, 12:04 AM #3
Check out this link------>http://www.drivetrain.com/parts_cata...d_pinions.html Doesn't have everything you need but it's a start!
11-27-2011, 03:28 AM #4
11-27-2011, 10:04 AM #5
To help with some of your questions on your 2004" Sierra with 3.73's,
.....Axle spline Count......30
.....Actual Ring Gear Diameter........8.625
.....Number of Ring Gear Bolts......10/Bolts
.....Standard or Reverse Rotation Front Ring & Pinion.......Standard
99" SILVERADO
11-27-2011, 03:26 PM #6
MAF reading 0 g/s on data list???
By 10mmguy83 in forum General Chevy & GM TechReplies: 4Last Post: 02-16-2011, 11:10 AM -
Camaro5Fest largest gathering yet of new Chevy ponycar owners - Autoblog (blog)
By Steve in forum Other GM CarsReplies: 0Last Post: 04-21-2010, 05:52 AM -
Trouble codes when regearing
By 05bluebeauty in forum GM Powertrain TechReplies: 15Last Post: 03-25-2010, 04:52 PM -
Regearing?
By Silverado1500 in forum Lifted & Offroad SuspensionReplies: 6Last Post: 01-21-2010, 08:01 AM -
Regearing - 03 silverado
By KC8QVO in forum GM Powertrain TechReplies: 12Last Post: 08-19-2009, 07:18 PM
VIGIL
HEARTBEAT
Bookmarks
