Results 1 to 10 of 12
    Default Debadging left behind ghost lettering ~ 2011 Chevy Silverado
    I have a new 2011 Silverado- bought it in September. I debadged the tailgate- used fishing line to remove the "SILVERADO" and the "LT" lettering. Goof-off & paper towels did a decent job getting the adhesive off. However, I'm left with outlines of the letters. The more "straight on" you look at the tailgate, (such as when you're walking straight towards the tail from a distance) the more noticeable it is.
    Can someone suggest a good way to remove this? Do I just need to use rubbing compound or something like that? For others who have debadged, do you see the same on your vehicle?
    Thanks
    Jr. Engineer McMahan's Avatar
    Jun 2011
    Korea (for now)
    Should have used bug & tar remover and not paper towels cause the stuff you used has caused paint to blemish or scratch and even fade worse off clear coat damage. Try rubbing compound and finishing wax to fix it but use a soft microfiber cloth not paper towels. Worse case senario is take it to a body shop and have them wet sand and buff it out
    2005 Silverado SS
    Color matched AEM CAI,Magnaflow mufflers,cat delete,true dual 2.75" stainless mandrel bent exhaust,Circle D 300K stall,Transgo shift kit,Corvette servos,Detroit Tru-trac,SLP 160* T-stat,Taylor 10.4mm red wires,Comp cams 228R,903 springs,12" cross drilled and slotted rotors,WHEATLEY tuned!!!! Boss 313 22X9.5,Toyo proxes II 305/45/22,
    Default micro-scratches
    Hi- thanks for the reply. It still elaves the question open, though- why is the lettering still visible? If the paper towel had scratched the clear coat, I'd expect to see at least some scratching where the adhesive came off. The spaces under the letters look perfect, though. Any thoughts? Is this just sun fading, and it'll even out over time?
    From that picture, it looks like there is some damage to the paint where the letters were - just not as bad as the rest because the adhesive was there to protect the paint from most of it. Like McMahan said, that is paint damage that will need to be fixed. Try some light rubbing compound (some are too abrasive), polishing compound, and then a good buffing. If that doesn't fix it, you will have to have that spot wetsanded and buffed to bring it back.
    Whatever you do, do NOT leave it to even out over time. That WILL allow the letters to permanently fade differently from the paint. And for future reference, the only thing paper towel is good for cleaning on a vehicle is glass. For your paint a microfiber cloth is always the right choice.
    X2 what pmf608 said.
    :cool:
    Weather Tech floor mats
    Cover-Craft seat covers
    Dash mat cover
    Formula One window tint
    One black Lab in rear seat.
    :glasses:
    Thanks all. I will have a go at it this weekend with some compound and microfiber towels and post the results here.
    Feb 2011
    fort stewart,ga
    i used goo gone on my truck and it brought it all off. just make sure you clean it very well after.
    Last: 09-04-2011, 10:50 AM
  2. Replies: 0
    Last: 08-25-2011, 11:40 PM
  3. SILVERADO lettering
    By hildy19 in forum General Classifieds
    Last: 03-24-2010, 12:12 AM
  4. Wanted...07-09 SILVERADO lettering
    By JAKD-UP in forum General Classifieds
    Last: 12-26-2008, 12:21 AM
  5. Croocked Silverado Lettering
    By SilveradoStud in forum Chevy Truck Accessories
    Last: 08-17-2008, 11:07 PM
