Results 1 to 2 of 2
    Default 2002 silverado brake and right. blinker problems(HELP)! ASAP
    So I had this problem before and it was fixed by the dealer and now I'm having the problems again and I'm about to go get the inspection sticker for the truck so I need help asap.
    Whenever I press the brakes the right blinker will light up but in a dim manner and none of the brakes will light up and when I need to use the right blinker and need to slow down at the same time the blinker blinks really fast and during the night it will just completely stop. I have no idea what it is and I need a permanent fix
    I had a similar issue with my 02. The wiring harness had become corroded. My plug was located on the rear cross member of the frame. I pulled it apart and cleaned it with contact cleaner. When I reassembled it I put some white grease on the plug to help prevent future corrosion. I did notice that the clip that held the plug together was broken, so I actually used some zip ties and held it together.
  1. brake light problem i need help asap
    By blake2395 in forum Chevy Truck Talk & GM News
    Last: 07-25-2011, 04:04 PM
  2. brake light problem i need help asap
    By blake2395 in forum Chevy C/K Truck Forum
    Last: 07-20-2011, 09:37 PM
  3. Need help asap with brake controller !! Please help !!!!!!!
    By cain73 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 11-23-2010, 09:41 PM
  4. 97 Tahoe - driver's side blinker and brake light doesn't work
    By BlackHawk99 in forum Audio, Video & Gadget Tech
    Last: 11-02-2009, 08:03 AM
  5. brake lites work blinker doesnt
    By mad_hungarian in forum Audio, Video & Gadget Tech
    Last: 09-11-2009, 06:56 PM
