    Default oil preasure gage drops, then goes back to normal
    hey everyone, i am new to this site.
    my oil Gage drops down to zero, but only for a few seconds and then goes back up to normal, does anyone know why this is going on? thanks alot,
    murdog94's Avatar
    Id change the OIL pressure sending unit on the back of the block. it is a common problem with these trucks.
    However YEAR, MAKE, MODEL, would help to better ID any other potential problems. Also motor size and tranny to.
    Mike
    Currently
    2011 F-150 Crew 4X4
    I had this happen on my 94 Ck1500 5.7 350. It would fluctuate alot and I started to hear an engine knock, well i took it to a mechanic and he did an oil change and used lucas oil stablilzer, fixed the oil pressure and engine knock, 3 months later happened again did an oil change and good as new so that could be an option if you have other issues along with the oil pressure going all over the place
    Will From Alaska
    -1994 Silverado z71 Extended Cab
    in the process of blacking it out
    original 350 5.7 liter engine with 122,000 miles
    brand new transmission as of may 2011
    I had this happen on my '93 Sierra with the 5.7. It turned out to be the semi-syn oil the dealer was using. It was too slippery for the pump and when you accelerated hard enough the pressure would drop. I switched to conventional oil and the problem went away.
    Quote Originally Posted by Kdubb2208 View Post
    I have a 04 Chevrolet Silverado RST has a 6.0 engine 26,000 miles and my oil pressure gauge has been dropping and going back to normal the engine sounds normal... Would like to know if you guys may know whats wrong with it
    Gauges in newer vehicles are electronic, not mechanical. A lot of things can make that happen, none of which may be any indication that the oil pressure is actually low. It could be simply a bad ground connection. If the engine were doing something that bad at 26,000 miles, you would hear noise.
    And other vehicles and toys.
    Quote Originally Posted by 04RegencyRst View Post
    How far is it dropping? Could be the stepper motor that moves the gauge.
  1. truck drops to 4cyl
    By ronniesk8 in forum GM Powertrain
    Last: 05-13-2010, 01:04 AM
  2. Voltage gage keeps pegging out
    By rays03z71 in forum Audio, Video & Gadget Tech
    Last: 04-30-2009, 12:36 PM
  3. Heavy gage steel
    By bac-n-afect in forum Chevy Truck Accessories
    Last: 03-03-2009, 11:00 AM
  4. Fuel gage is acting up - sending unit?
    By trailblazer58 in forum General Chevy & GM Tech Questions
    Last: 10-30-2008, 11:24 AM
  5. Oil Preasure Gauge
    By KD7ONE in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 03-06-2007, 07:41 AM
