    Default 5.3L miss question
    Hi, I have a 2003 yukon with a 5.3L. I noticed that if I leave it in park and give it gas to get to between 900-1000 rpm, it runs alittle rough. I went to my buddy's house yesterday and he has a 2006 silverado with the same motor half the miles as mine. So we tried it with his. Same thing, idles smooth, runs fine in gear. But, when it is between 900-1000 it feels like it runs unbalanced. Anyone else notice this? If you don't mind, Try it on yours and let me know. Its not like it matters, it idles at 600rpm and when in gear it is always over the rough range. I was just curious if anyone else has the same issue, and if anyone knows what would cause it. Has new plugs, fuel and air filter, MAF was just cleaned, Throttle plate cleaned. I'm stumped.
    murdog94's Avatar
    Which plugs are you running in it?? AC delco Platinums/Iridium plugs are all you want to run in the Vortec motors.
    And did you pull the the Throttle body to clean it or just do it with it on the motor. because if it was still on the motor you will want to pull it off and use a Throttle body cleaner on it. As to the rough idle.. come to think of it yeah, my 5.3s that i have had were a touch off but nothing really noticeable.
    Mike
    Currently
    2011 F-150 Crew 4X4
    I cleaned it on the truck. I only run the plugs indicated in my manual. Only AC delco not the NGK that they list. (I get them free). The roughness is hardly noticeable. I actually had to point it out to my friend as he did not even feel it. At idle it runs perfectly smooth, it just gets rough between 900-1000 rpm. Most people would probably never notice it.
    murdog94's Avatar
    Yeah it may just be a fault with the TBI motor not wanting to adjust the trim properly, since as i said with my 5.3Ls that i have owned i had noticed a bit to but never really thought much of it since well, as you say it isnt really noticeable..
    Mike
    Currently
    2011 F-150 Crew 4X4
  1. Low idle miss...
    By daddytech in forum General Chevy & GM Tech Questions
    Last Post: 01-13-2010, 06:54 PM
  2. miss at idle
    By jason2188 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 05-21-2009, 12:47 PM
  3. Need help with miss on 99 k2500-5.7L
    By 99blueburb in forum GM Powertrain
    Last Post: 11-19-2007, 08:45 AM
  4. help with miss on 99 K2500 with 5.7L
    By 99blueburb in forum Performance & Fuel
    Last Post: 09-24-2007, 11:09 PM
  5. help! engine miss
    By lrrymrtn in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 02-06-2007, 12:10 PM
