    Sr. Engineer tigersdl65's Avatar
    May 2009
    Tallassee, Alabama
    Default Parking brake help
    I took my truck to the shop to get new brakes all the way around, a full job. I got back home and realized my parking brake no longer holds. There is tension on the pedal so how do I fix it and make it hold?
    Schrub!:sign0011:
    Year/model?
    I have similar problem on my '98 Silverado. Sounds like you ought to take it back to the shop that did the brake job and make them fix it? Otherwise, probably an adjustment is needed at the rear drums or discs.... depending on what you have. I am in the process of trying to figure out how to do this right now. There is another adjustment point under the frame in front of the rear wheels (depending on year, model) but I'd bet that is not where your problem is. Good luck.
    Sr. Mechanic Ethan's Avatar
    Sep 2009
    Cedar Park, TX
    Assuming they did the brakes correctly, you can either adjust the brake slack via a hole in the back of the drum plate until the drum spins for a second and stops, or brake hard in reverse a bunch of times. On most Chevy trucks with rear drum brakes, they are self adjusting every time you brake in reverse.
    1994 Chevy Silverado 1500 Ext Cab 350 cuin TBI in dark Chevy blue
    160,000+ miles
    Original paint
    Original interior
    Original engine and tranny
    wrecked twice stolen once
    Diamond Plate bed rails
    Power windows
    Original Alloy wheels
    Original fancy smancy cup holder
    Tow package
    Original plastic bed liner
    K&N Cone Air Intake
    Dual MagnaFlow exhaust(not true dual) with chrome tips
    MSD Street Fire Performance Ignition coil
    Well I'm assuming you have a rear disk setup. If they put new rotors on they obviously did not adjust the e brake shoes. It's an easy fix but your mechanic should fix for free due to the fact they did work on the rear brakes, period. That was what you paid for, right. If you want to attemt yourself just pull your calipers and rotors and depending on what side it is the adjuster will be on the top or bottom. Just grab a screwdriver or small prybar and spin the adjuster in small amounts. After a little adjustment throw your rotor back on and check. i adjust mine until you can barely hear them drag on the inside of the rotor, just barely.
    "If it ain't one thing, it's a mother******g nother"
  1. Parking Brake
    By 03LThoe in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 08-11-2011, 01:51 AM
  2. Parking Brake Question
    By rs6er in forum General Chevy & GM Tech Questions
    Last Post: 01-03-2011, 05:44 PM
  3. '99 S-10 Parking Brake Schematic?
    By VaqueroAZ in forum General Chevy & GM Tech Questions
    Last Post: 11-22-2010, 09:45 PM
  4. Parking Brake Sticking on 05
    By hearseman in forum Chevy Colorado Forum (GMC Canyon)
    Last Post: 05-30-2010, 08:41 AM
  5. Parking brake ?
    By FireRed in forum GM Powertrain
    Last Post: 10-21-2007, 01:25 PM
