Results 1 to 2 of 2
    Default Want to ad cruise control...what do I need
    I want to ad cruise to my non cruise 02 Silverado with the 6.0
    I have already changed the turn signal lever out to a cruise control factory lever.
    I also checked both fuse locations and insured they have good fuses installed.
    What else do I need? I was thinking I need a CC servo unit under the hood. If I install that will the CC work? How difficult is it to install and are the mounting bolt locations under the hood already there?
    Can some one send me a good photo of a servo installed and the connection at the throttle body.
    Thanks
    Okay I have never looked at an 02' Silverado, but does the throttle body have linkage or is it drive by wire setup? If it has throttle linkage (cable), then you would mount it on the driver's side fender well and the cable would run inside to the back of the gas pedal. I would say you would have to get a new pedal assembly but not sure. The cruise control also works off the brake switch, and the TCC PWM on the transmission. I did this upgrade on my 97' Firebird, took about 2 days for me to figure it out lol, trial and error....
  1. Cruise Control WTF?!
    By GreatCaesar in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 02-11-2011, 11:10 AM
  2. Replies: 3
    Last: 12-03-2010, 06:40 PM
  3. Cruise Control add-on?
    By jamesdeanj in forum Chevy Silverado Forum (GMC Sierra)
    Last: 04-19-2010, 07:47 AM
  4. cruise control
    By TheUnit in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 12-29-2009, 08:21 PM
  5. Cruise Control??
    By imthatgirl in forum General Chevy & GM Tech Questions
    Last: 03-01-2008, 10:24 AM
