    Default I now gota push my break in pretty far and my dashboard break light warning comes on?
    I need help with this because its only been recent but ive felt that ive been pushing a little
    more and more and now its getting scary because i dont know if that means the breaks will give out?
    Im pretty sure its not the pads cuz they arent old but i need suggestions asap. thank you!!!
    A little more info on the truck will help.
    even though not old check the condition of the pads and rotors.
    look for leaks in the brake lines/check level in master cylinder.
    Does it buld pressure if you pump the brakes?
    If so then could be air in the lines/master cylinder.
    If not then could be leaks, bad booster, bad master cylinder.
    If you are fairly handy take a look. if you really dont have much knowledge or experience with brakes then I would suggest taking it to a shop as its a great safety hazzard and would like to keep you and everyone else safe if something in the braking system is failing.
    David
    1960 Land Rover Series II 88
    2001 Pontiac Sunfire
    NRA Life Member
    Newbie
    Dec 2011
    concord north carolina
    Quote Originally Posted by dsfloyd View Post
    all is covered lol.
    yea im pretty handy, I was just hoping for a headstart before i start guessin, btw its a "97 silverado" probably should have said that before.
    the breaking is very strange, when i pulse it it sort of builds pressure yet it doesnt at all? very hard to explain thats why i need suggestions haha
    ive owned the truck for about 6 months and over the course of that time ive had to push the break further and further and now about everyother time that little light comes on and i cant search what that means because when i type in anything about break light coming on it obviously only brings up like break/tail light information not the small in dash light
    ok then ya I would check for the fluid level/leaks, bulging or soft spots in the rubber lines. from there possibly a master cylinder or brake booster issue.
    i checked the fluids last night and they looked fine? doesnt mean i didnt look wrong haha will for sure double check, thanks
    Would my breaks just give out eventually because of this?
    Newbie
    Dec 2011
    i have a 96 and the master cylinder started leaking on it.you could possibly have air in the lines as well my bleeder valve kept coming loose on drivers front and i ended up with the same symptoms so i replaced it as well.
  1. How To Make a Custom 3rd Break Light Cover
    By FrigginNoodles in forum How-to Guides
    Last: 02-16-2011, 08:54 PM
  2. Break light switch.
    By tmahan319 in forum General Chevy & GM Tech Questions
    Last: 10-11-2010, 08:58 PM
  3. ABS and break light
    By vaugeois1985 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 05-07-2010, 02:38 PM
  4. break light problem
    By cwbontheyfz in forum General Chevy & GM Tech Questions
    Last: 12-05-2009, 12:56 PM
  5. Fyi - Third break light assembly water leak
    By TMRuiz in forum Chevy Silverado Forum (GMC Sierra)
    Last: 02-23-2009, 10:59 AM
