Results 1 to 10 of 13
    Default Door handle, shocks, leaking dash, oh my!
    Just when I thought I took care of all the minor maintenance my new 99 C2500 needed, a new batch crops up. I can no longer open my driver's door from the inside, I bought new shocks but lack the tools to remove the old ones myself, and my dash rains on the feet of my passengers when driving in the rain. Uggh.
    think I'll start with the door handle. Then I'll see what a shop will charge to install the shocks I bought. And since it's winter here in Michigan, I'll hold off on the down-pouring dashboard.
    Happy Holidays!
    Luke - Michigan
    1999 C2500 Suburban LT
    2009 Subaru Legacy Limited
    Look on the bright side. At least you don't have a new car payment. Pick up some tools and play around with it. These things are fun and easy to work on, kind of like fixing up an old car. Merry Christmas!
    1996 GMC Suburban K 1500 "The Love Boat"
    Magnaflow cats
    Flowmaster catback exhaust
    BFG 285/75/16 on stock 16's
    K&N with Cold Redneck Air Intake
    Monroe Reflex Shocks
    A whole bunch of new stuff -with-
    more to come
    Apr 2009
    The door handle problem should be a simple fix, but I can see how replacing the shocks could be a difficult task without any tools. I've never heard of the dash leaking though....
    2005 Chevy Silverado W/T
    Planned mods not in order
    In the winter the leaking dash is fine, until the snow melts and here in Michigan that can be tomorrow. I would check under the hood. Look along where the heater lines come in. Also check the rubber gasket that seals near the windshield wipers when you close the hood. The door handle is an easy fix. Either the rod came off or the handle broke. On my 95 the handle broke where the rod attaches. Monsterautoparts.com has that handle for around $20 if you need a new one. http://www.monsterautoparts.com/CHEV..._door_han1.htm Do you need special tools to do the shocks or just wrenches and some sockets? There are some crazy cheap deals at sears right now for the large mechanics set of tools.
    I've seen a few threads about the leaking dash here. Water is collecting in my heater vents (I can hear it move when I turn corners) so I think the best lead I've seen is the seals around screws by the wipers that are right over the air intake for the ventilation system. Just too cold to tear it all apart and look for it.
    The door handles look easy enough, other than mention of a rivet I'll need to remove and replace with a screw. But I never considered that it just fell off rather than breaking. Will have to check that.
    The shocks either have bolts buried by the frame that I must need an elbow socket or something to get to (driver's rear) or the top nut needs to be cut off with a torch or something (driver's front). I was hoping a standard socket and wrench set would be enough. Wrong. Also looks like I need a taller floor jack. Mine is rated for the weight but just doesn't have the height for this truck. Hope Santa shops at Sears.
    Luke - Michigan
    It is supposed to be in the 50's on Thursday, plenty warm to look at the leak . If I remember correctly, I was able to change the front shocks out with two wrenches. It takes forever but, it worked. Yes, you can carefully cut the nut off with a torch. But, you when you put the new one on you still have to spin the nut on. So there has to be a way to get the old one off with wrenches.
    Caddiac's Avatar
    May 2011
    Upstate South Carolina
    Quote Originally Posted by EzraBrooks View Post
    I brought the pop rivet gun and the rivet and put it back in correctly. It was easy enough and the part I purchased on line was very affordable and the color matched perfectly. The rivet hole, as I recall is a large and you don't have a lot of room for it to protrude into the door though it could be different depending on your trim level. Short and fat sheet metal screw might be harder than the rivet.
    As for shocks, I am still running the originals in my 98 and it still rides better than the Ford from the same model year. Probably give a new F-150 a run for its money. LOL
    I have not experienced any issues with windshield leaks. I know there is a drain for the A/C that can get plugged and cause the a/c to leak. It is a stretch but might be worth checking just in case in also doubles for water that might come in.
    86 911 Porsche Carrera
    98 K1500 Suburban LT
    2012 Nissan Leaf
    ​General Motors.
    Because life is too short to drive a Ford
  1. Dash Grab Handle removal - 2000 Sierra ???????????
    By Dante04SRT in forum General Chevy & GM Tech Questions
    Last Post: 11-21-2011, 05:49 PM
  2. Replies: 0
    Last Post: 10-18-2011, 01:00 AM
  3. Hot, Cold Air Diverter Door Actuator or Dash Switch??
    By Velocity1 in forum General Chevy & GM Tech Questions
    Last Post: 09-25-2011, 12:05 PM
  4. Strange sound from under the dash, not door alarm.
    By backcountrycruiser in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 04-16-2010, 12:41 AM
  5. Door panel and dash removal? '07 Silvy
    By axlman in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 08-05-2007, 03:19 PM
