    Default 98 Suburban 4wd question?
    Just bought a 98 Suburban K1500 i have a question about the 4wd..The switch doesnt see to light in any postion,2wd,auto or 4hi or 4lo but seems to work,then sometimes the light does go on in 2wd drive only?...What causes this?...is there any way to fix this?....Thanks...
    1998 Chevy Suburban K1500
    Greets,
    Press hard around the switch site and see if they light up. A few of us have had loose contacts on the back side of the plugin.
    Nag.
    .....ya clock faster and faster till the desire for speed overcomes the fear of bus.....
    Quote Originally Posted by NagRuTan View Post
    Greets,
    Nag.
    Thanks how does that switch come out so i can check that and clean the connections up?....
    Quote Originally Posted by My98Suburban View Post
    Greets,
    I pulled the dash to get to it. Not to hard (at least on my 99).
    Nag.
    Ok i will try pressing on the switch 1st then what else could it be if it doesnt go on? lite up?
    My switch works fine, but it has a hole in it. I think the previous owner always pushed on it too hard and broke through the lit up part of the switch, where the plastic is thinnest. I plan to find a new one and just swap it out. You should consider doing the same if it's not a loose connection. At least the 4WD works. A switch is a cheaper fix than a solenoid or a transfer case!
    I like you.
  1. 89 Suburban a/c question
    By Txflats in forum General Chevy & GM Tech Questions
    Last: 07-13-2010, 10:33 AM
  2. question with 4wd 03 suburban
    By au5599 in forum GM Powertrain
    Last: 12-28-2009, 02:09 PM
  3. Suburban A/C Question
    By romangiberson in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 07-31-2009, 08:27 AM
  4. Suburban A/C Question
    By romangiberson in forum Member Introductions
    Last: 07-28-2009, 11:13 AM
  5. 96 5 lug suburban question
    By westcoastjay in forum Lifted & Offroad Suspension
    Last: 05-18-2009, 06:21 PM
