Results 1 to 10 of 11
    Default This is how to bypass onstar!!!
    Their is a 6 pin connector on the back of your stereo. Grab the pink wire which i believe its remote for the stock amp. Then grab your new head unit remote wire and join those two and your set!
    Moderator
    dwill3015's Avatar
    Jan 2007
    Yacolt, Washington
    Great to know! Where did you get the info?
    Darcy
    Washington State
    got it from an avalanche forum and i tried it myself and it did work!!!
    Moderator
    dwill3015's Avatar
    Jan 2007
    Yacolt, Washington
    Sweet! That will be useful for the future (I have a 2001 Suburban).
    Thanks for sharing!
    Darcy
    Washington State
    just a thought.... if you guys, or me, or anyone for that matter, are "bypassing" all this factory installed equipment, FUSE EVERYTHING!! if your going to be jumping wires and things like that, its not a bad idea at all.
    i had a guy in the shop, today actually, that tried to bypass a DVD player and completly fried his ignition wire all the way from the radio, to the computer!! lots of smoke, no more radio and about $200 later, he wishes he would have put a fuse on there! so, just wanted to share that info with you guys!
    GOOD LUCK!!
    Cody- Tulsa, OK
    '04 silverado
    Master Mechanic
    lancer's Avatar
    Aug 2009
    Farmersville, Illinois, United States
    thank you!!!! i just bought a 2002 tahoe and trying to put my 7" monitor in and i had it all hooked up and now sound. no bose, does have the sub and onstar. i put the stock radio back in hooked up both plugs worked fine, unhooked the small plug no sound. i will try this in the morning, really wanting to get the thing back together to enjoy it this weekend!!!!
    2002 Tahoe LT---------TINTED WINDOWS------------7" DUAL DVD INDASH
    Default 06 Tahoe
    I was wondering if this will work my 06 Tahoe with onstar and steering wheel controls
    Master Mechanic
    lancer's Avatar
    Aug 2009
    it worked perfect in my 02 but i don't have my onstar hooked up anymore and i don't have the wheel controls. you can get they head unit all wired up and just shave the coating off the pink wire and see if it works. also i think you need a module to hook up to make the wheel controls work with an aftermarket head unit, i think but don't hold me to it!!
    Sep 2011
    Fairbanks, Alaska
    Real quick. This needs addressed before someone Fs up their truck. An 02 wiring system is WAY different then an 06. First off, in 02 it was still an analogue setup and the harness kit only cost a whopping 20 bucks. Second in 03 GM introduced the CAN system. It's a form of reduced data they used to help simplify the wiring system, basically, one wire does multiple things using fluctuations in resistance in the ground circuit (DC current travels from the negative terminal of the battery towards the positive ie. "the electron flow theory"). Now in 04 they introduced the CAN-BUS system, same theory, slightly refined for more efficiency. The CAN systems are most obvious in the lock circuits, headlight circuits and radio circuits, the radio circuit varies a HUGE amount from 02 to 06, if you "tap" into some unknown pink wire behind your deck and force feed 14.4volts through it, your playing with fire, you will most likely overload a reduced voltage multiplexed circuit and smoke components not excluded to the radio system.
    Secondly, you do need a module to retain your factory steering controls.
    Iam glad you posted this info....someone was going to really screw something up trying to save a few dollars on a harness.
    The time you spend splicing wires you could have installed the right harness twice.
    Get the Gorilla!
    gorilladip.com
    sales@gorilladip.com
    Last Post: 01-09-2010, 10:10 PM
  2. oil cooler bypass
    By 454Caddy in forum General Chevy & GM Tech Questions
    Last Post: 09-15-2009, 07:04 PM
  3. Bypass o2 sensors
    By 99 Z71 in forum General Chevy & GM Tech Questions
    Last Post: 09-04-2009, 08:42 PM
  4. o2 sensor bypass
    Last Post: 07-30-2009, 10:43 PM
  5. How do i bypass onstar???
    By 01subowner in forum Audio, Video & Gadget Tech
    Last Post: 12-02-2008, 01:58 AM
