    Default electrical problem 2004 colorado
    I have been having problems with just the driving (parking) light socket on the passengers side. it seems to work fine for a while then it gets hot and either blows the bulb or just doesn't work any more. Does anyone have any suggestions on how to fix this?
    stephan's Avatar
    Far West, Oregon USA,
    I would look close to where the heat is being generated. High resistance in electrical circuits causes heat, which in turn causes even higher resistance & even more heat. This can be a loose connection, loose bulb in the socket, loose wire connection, corroded socket, anything that is not tight or clean. I would look for your problem close to where the heat is.
    3" susp. lift kit "shadetree"
    is there a way to tell if there is a short in the wire or if the ground is bad?
    stephan's Avatar
    If there was a short to ground in the power wire, it would blow the fuse. If the ground wire is loose or corroded then yes this could cause it, same with the power wire. Any loose connection, or corrosion in power or ground wires will cause high resistance & heat.
    thank you. hopefully this will fix the problem
    gd i have the same problem with blowing bulbs, esp on rt rear normally turn signal bulb, i found i had a cracked lense so i cleaned it and used some good silicone caulking ( clear ) and cailked the crack, replace the socket, ( the socket was getting moisture in it esp. during automatic car washes ) make sure you put electrical grease in all sockets when installing new bulbs this will make better connections and keep any water out, please note the crack can be real slight good luck ken ( marine 59 )
  1. Minor Electrical issues with 2004 Colorado that are annoying
    By ajbellis in forum Chevy Colorado Forum (GMC Canyon)
    Last Post: 07-08-2011, 08:17 PM
  2. Electrical Problem
    By bldawson89 in forum General Chevy & GM Tech Questions
    Last Post: 03-06-2010, 07:24 PM
  3. Electrical Problem
    By bldawson89 in forum Member Introductions
  4. Electrical problem
    By '90_400 in forum Audio, Video & Gadget Tech
    Last Post: 12-08-2008, 08:53 AM
