GM Truck Club
Page 4 of 4 FirstFirst ... 234
Results 31 to 32 of 32
  1. #31
    Default Update
    Okay- here's the deal so far.
    Transfer case is WAY too loose. While lying on the floor, I can push up on it until it almost touches the floor of the truck.
    I put shop lights underneath and saw what thought was a crack in the case near the mount. Turns out, I think it's supposed to be that way- I didn't realize that it goes into the mount... so then I felt around it.
    Basically, one of the bolts from the mount into the case is hanging loose. Another that should be into the bottom of the case near the base of the mount is missing.
    I'm new to this, so bear with me. I have video to post at some point.
    I'm taking the brace that the mount sits on down, after unscrewing the mount bolts into the brace. I'll update later.
  2. #32
    Quote Originally Posted by k.daddy1 View Post
    Just for grins and giggles, pull the diff cover off. Your probably going to find the problem there. Those rear ends are week and are known to strip the gears. I've replaced three rear ends on 97-03 in the last 2 months for basically the same symptoms your discribing.
    I doubted the rear end was the problem, but pulled the cover off since I was going to inspect and refill with fluid anyway.
    Old gasket looked good and gears looked good. Old fluid wasn't burnt or filthy. Not much for shavings in fluid.
    http://picasaweb.google.com/lh/photo...eat=directlink
    It's the transfer case. More on that later.
Similar Threads
  1. 4 wheel drive grinding noise
    By BradG in forum Chevy Silverado Forum (GMC Sierra)
    Last: 02-01-2010, 02:31 PM
  2. Grinding Noise when driving
    By RedRocket01 in forum General Chevy & GM Tech Questions
    Last: 06-04-2009, 01:15 PM
  3. cant believe it - Silverado Grinding Noise
    By 06piney in forum Chevy Silverado Forum (GMC Sierra)
    Last: 03-05-2009, 11:21 AM
  4. grinding noise in 2WD HI
    By EdPDX in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 12-18-2008, 05:15 PM
  5. Grinding Noise In Transfer Case
    By CMXIII in forum Chevy Silverado Forum (GMC Sierra)
    Last: 07-09-2007, 01:43 AM
