View Poll Results: Air or Nitorgen
Voters
53. You may not vote on this poll
  • Air
    37 69.81%
  • Nitrogen
    16 30.19%
Page 4 of 5 FirstFirst ... 2345 Last Post byLast Post by
Results 31 to 40 of 49
  1. #31
    With the nitrogen, I never seem to loose any air pressure.
  2. #32
  3. #33
    Quote Originally Posted by tiltonb View Post
    I use propane in a pinch.
    Wonderful idea
    To all those who see value in paying $10, or more, per tire for N2.......................you are aware, that good old air is 78% Nitrogen
  4. #34
    I have had nitrogen in my last 4 sets of tires I bought. Unless I pick up a puncture the pressure seems to remain constant. Most tire places in Michigan (or at least near me) put in N2 for free when you buy the tires. If something happens when I am on the road, I will fill up with air and when I get home the tire place will take the tire off the rim (to patch the hole) and refill with N2. My mother in law lives in Ohio and the local tire place wanted $25 per tire to put N2 in. The place up the street charges $3 each if you did not buy your tires there.
  5. #35
    $3.00 is a good deal, I would use N2 at $3.00/tire
  6. #36
    In the area I live in outside of the dealership nobody service's with Nitrogen, the dealership charges $10 per tire to fill up or adjust the pressures.
    My wifes car needed all 4 tires topped off about every other month for the last year they had nitrogen in them, that stopped and I serviced them with good old air as soon as I realized she was paying $40 every time I told her to "just go get air in your damn tires at the dealership" since she drove right past it on her way to work. Since filling them with air 18 months ago I havent had to service them yet, and if they do need servicing she can go to the Discount tires next to her work for free since I bought a new set of tires from them 6 months ago.
    My truck will be a year old next month and the nitrogen has had to be serviced once when the truck was 6 months old when I brought the truck in for an oil change (they did it for free since I bitched about having to pay $40 to service with nitrogen that supposedly is so great that I dont need to service it that often) and the tires need to be serviced again now 6 months later, I'll pull my compressor out and do it this time.
    I said it before and I'll say it again nitrogen is not all it's hyped up to be, it certainly isnt worth $10 a tire not counting how much more you'll have to spend keeping the tire properly serviced for the life span of the tire.
    Having worked in Aviation for 25yrs I know even aircraft tires require servicing, some as often as every other day, the only good thing about nitogen is it isnt as influenced by heat and cold, but that doesnt mean you wont ever have to service it, and at $10 a tire it just aint worth the expense.
  7. #37
    This is exactly what I was going to say. Air does just fine and is free. Why pay for nitrogen when regular air is mostly nitrogen anyway? It's like paying for bottled water....
  8. #38
    Sr. Apprentice 87silver's Avatar
    Oct 2012
    Hudson River Valley, NYS
    Get real, pay for nitrogen? I must say that back in the '80's we were some of the few running ATCs and ATVs. We used to inflate the tires with nitrogen due to the requirement of low pressure (2.2-3psi) and moderate temp changes (40F-80F), because we went on multiday outings at extreme altitude changes. But for road vehicles where pressures are much higher and temp changes are much more gradual, it really comes down to paying for convenience or laziness.
    HHR SS_________________The Heritage Hot Rod
  9. #39
    I use air, because i would not know where to get nitrogen around here
    1994 GMC Yukon, 2 door, Victory Red
    Garage Link: http://www.gmtruckclub.com/forum/sho...1994-GMC-Yukon
  10. #40
    Nitrogen on vehicles with the tire pressure system.
    Nitrogen for trailer tires that sit around a lot.
    Air for the rest.
  1. Nitrogen Tire Inflation
    By 1flyfisher in forum General Chevy & GM Tech Questions
    Last: 11-26-2010, 11:03 PM
  2. Replies: 0
    Last: 11-05-2010, 12:14 PM
  3. Bridgestone Tires - Replacement Tires
    By jhonydeep in forum Wheels & Tires
    Last: 05-03-2010, 08:03 PM
  4. Tires tires tires Arg! 10ply vs others Road hazard
    By Dr_Zero in forum Wheels & Tires
    Last: 02-20-2009, 01:09 PM
  5. Blizzak tires, snow tires need advice.
    By EdPDX in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 12-12-2007, 06:58 AM
