View Poll Results: Air or Nitorgen
Voters
53. You may not vote on this poll
  • Air
    37 69.81%
  • Nitrogen
    16 30.19%
Page 5 of 5 FirstFirst ... 345
Results 41 to 49 of 49
  1. #41
    I use air because air is everywhere, nitrogen isn't around enough to randomly get it. On the flip side, a customer bought rims/tires and they were filled with nitrogen, they haven't lost a single psi in 8 months.
  2. #42
    Jr. Engineer Jamm3r's Avatar
    Dec 2012
    Minneapolis area
    Not much difference between nitrogen and dry air.
    Some folks say that the oxygen in the air binds with the metal in the rim or the rubber in the tire leading to a loss of pressure. I'm not so sure that goes on, and to the extent that it does, it is used up leaving... mostly nitrogen.
    You all do check your tire pressures at least once a month, right?
  3. #43
    Quote Originally Posted by Jamm3r View Post
    Actually, at every fill up! I scroll through all of the options in my DIC to reset my average mpg and my trip, I pass the tire pressures on the way so I check them out also.
  4. #44
    ...and having a tire pressure monitoring system is another reason to use the less corrosive nitrogen. ;)
    Buy Made in USA, The job you save just might be your own.
  5. #45
    Quote Originally Posted by E_HILLMAN View Post
    .. another reason to use the less corrosive nitrogen.
    Ok, you'll have to explain that to me. Other than a few pollutants, what is corrosive about the air you breath.
  6. #46
    Oxygen by nature causes oxidation, without it you wouldn't really have rust etc. With the nitrogen (if you are getting a good more pure fill of it) you have MUCH less Oxygen thus you have less of a reaction. The tire monitoring system is sensitive and thus any corrosion you can keep down from them will make them last longer.
    Or if you want a more intelligent reply than I can give. (LOL)
    http://wiki.answers.com/Q/Why_is_the...ygen_corrosive
    Answer:
    Oxidizing compounds
    Oxygen gas (O2) is a pretty good oxidant (in fact, the word "oxidize" comes from "oxygen"). This is because oxygen is fairly electronegative. When bonded to itself, it forms a purely covalent bond. In contrast, when bonded to many other elements, in particular to less electronegative metals, oxygen is able to have more electron density for itself. So oxygen gas will react with other elements, such as iron, and then rust or corrode them. Other very corrosive elements are F2, Cl2, and Br2, all for the same reasons -- they are very electronegative, and by combining with something other than themselves, they are able to gain more electrons.
    Also note that burning is the same process as rusting, although we don't think of it that way! Both are just something combining with oxygen. Compare the two reactions:
    Rusting of iron: 4Fe + 3O2 --> 2Fe2O3
    Burning of methane: CH4 + 2O2 --> CO2 + 2H2O In fact, burning is just oxygen combining with the fuel (whether it be wood, oil, gas, coal, or anything else) to form products in which the reactants are oxidized. So oxygen is in fact quite reactive with many things. Usually to get things to burn, you need a spark to get the reaction burning though (there is an activation barrier to the reaction, but it is an very exothermic reaction). Rusting is also quite exothermic, but it is kinetically slow.
    http://www.engineeringtoolbox.com/ox...on-d_1170.html
    Using good Nitrogen instead of "air" can also keep cheaper aluminum wheels from oxidizing and causing tire leaks as many have had issues with.
  7. #47
    While in theory I agree with the answer, the problem is when servicing tires their never properly prepared for a Nitrogen charge so technically all your really doing is slightly slowing down the corrosive affects.
    To properly create a non-corrosive environment inside the tire you would need to do a hot purge of dry Nitrogen at 120deg until the tire and rim reached a temperature of 120deg and for not less than 40 minutes to ensure the total space inside the tire was properly purged (given calculations of the average tire size and cubic space inside) anything less than this would not guarantee a total Nitrogen environment, it would be diluted and thus susceptible to corrosion. Which is why the American Gas Standard doesnt endorse servicing tires with Nitrogen since you cant achieve a complete and undiluted Nitrogen fill.
    To properly fill and service a tire with Nitrogen would require two valve stems so you had an outlet for the hot purge gases.
  8. #48
    Oxygen by nature causes oxidation, without it you wouldn't really have rust etc. .
    I agree, oxygen is an oxidizer, but not necessarily corrosive (oxidization is not always a bad thing). It requires a moist environment to reactive with iron to form rust. If by it's very nature, it rusted sheet steel, vehicles from the "dry" states would be rusty.
    Air is (if I remember correctly) 78% nitrogen and 16% oxygen, unless you purge the air (as @tbplus 10 suggested) out of the tire before you fill with nitrogen, you will still have some oxygen.
  9. #49
    Indeed but every bit that helps slow it down is good with me.
    Oxidation does not need much if any moisture to happen. Rust might but even your plastic parts can get oxidation.
  1. Nitrogen Tire Inflation
    By 1flyfisher in forum General Chevy & GM Tech Questions
    Last Post: 11-26-2010, 11:03 PM
  2. Replies: 0
    Last Post: 11-05-2010, 12:14 PM
  3. Bridgestone Tires - Replacement Tires
    By jhonydeep in forum Wheels & Tires
    Last Post: 05-03-2010, 08:03 PM
  4. Tires tires tires Arg! 10ply vs others Road hazard
    By Dr_Zero in forum Wheels & Tires
    Last Post: 02-20-2009, 01:09 PM
  5. Blizzak tires, snow tires need advice.
    By EdPDX in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 12-12-2007, 06:58 AM
