Page 1 of 3 123 LastLast
Results 1 to 10 of 27
    Default truck knocks on startup :/
    1990 k1500 .. 350 knock for about 25 seconds upon startup and the the knock goes away .. would really like to know what the issue is ..?
    How many miles on the motor? Could be worn bearings.
    78 GMC High Sierra K1500
    185000 on the odomoter i dont know how much on the actual motor
    The knock is most likely caused by excessive bearing clearances. The only way to tell for sure is to pull a bearing cap and check.
    as that a big project ... i just tore apart my front differential to change the clips that hold the spindle shafts in place and that was a big project. i just cannot afford another big project at the moment ..
    my buddy told me the oil filter may be too restrictive and not allowing oild to enter as quickly as it should
    this happens to mine as well. but chevrolet says as long as it goes away then it shouldnt damage anything. mines done it since 30k and im about to hit 190k with no issues. its worse in the cold correct?
    What Chevy doesn't?
    -2001 Suburban 2500 LT 8.1
    -2000 Silverado 1500 LT Z71
    Gone but not forgotten:
    -2007 TrailBlazer SS
    -2004 Cadillac CTS-V
    -1998 Silverado 1500 LT Z71
    -1989 Pontiac Formula WS6
    Quote Originally Posted by maasmania View Post
    A Dealer told you that? Please tell us which one so they can be avoided. Lifter clatter is common on cold mornings but rod or main bearing knock means a badly worn motor.
    Quote Originally Posted by Boonduff View Post
    Rod or main bearing knock wouldn't go away after 20 seconds.
  1. Wining noise a few minutes after startup
    By msvx95 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 01-14-2013, 07:58 AM
  2. Knocks and Falters
    By wherewasi in forum GM Powertrain
    Last Post: 08-20-2010, 11:53 AM
  3. Truck has low idle/knocks off
    By kgibson181 in forum GM Powertrain
    Last Post: 06-29-2010, 12:58 PM
  4. noise after startup?
    By 2wheelmudder in forum GM Powertrain
    Last Post: 06-06-2010, 04:00 PM
  5. engine rattling at startup
    By tic in forum GM Powertrain
    Last Post: 03-02-2009, 10:25 AM
