    Default Recon Projector Headlight Adjustment?
    I just got a set of Recon projector headlights for 07 Silverado. The beams are way off on them and I need to adjust them, I am not sure how to do this. If anyone can help me out that would be greatly appreciated!
    Thanks
    Here are the steps on how to adjust your Recon Headlights.
    1. Make sure there is little light (make the adjustments at night)
    2. Vehicle should be on a flat surface against a flat wall
    3. Park vehicle 30 feet from the wall and turn your lights on
    4. On the back of your Recon Lights, there should be 4 adjustment screws
    5. Adjust them until the beams are 2” below center of the wall
    Hope this was helpful. Good luck!
    One Source for all your Truck & SUV Accessory Needs - customtruckpartsinc.com
    Thanks for the info. I finally got them adjusted, unfortunately to do that I had to remove the passenger side headlight to access the adjustment. There is no way to get at it with out taking the light out. As far as the adjustment goes, there is only an up and down adjustment for the Low Beam, while the High beam has 2. Thanks for your help!
    Bob
  1. Recon Projector Headlight Adjustment
    By RagsCo4 in forum Lighting Discussion
    Last Post: 02-01-2012, 03:03 PM
  2. ANZO or RECON Projectors? IPCW or RECON Tail Lights?
    By Fonze in forum Chevy Truck Accessories
    Last Post: 10-11-2011, 09:33 AM
  3. RECON Projector Headlights
    By Drake_korthos in forum Photo & Video Gallery
    Last Post: 10-06-2011, 08:49 PM
  4. recon projector headlights????
    By 4.8chevysilverado07 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 05-20-2011, 01:42 AM
  5. 99 Burb Headlight Adjustment
    By Country Cadillac in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 03-21-2009, 09:56 PM
