    Default How widespread is the Castech head crack?
    I just wonder how big of a problem this has been since there must be 10's of thousands of these motors out there.
    I guess I am just concerned since I just bought one with the 706 casting.
    Should I nip it in the bud and go ahead and replace the heads now?
    I do have another question that may be easier to answer/talk about.
    Are all the 706 heads made by Castech? Or is that why you have to look inside to see the Castech marking?
    I know I have the 706 cause I can see it clearly on the outside of the head passenger side.
    I found this about identifying the Castech heads. It does not indicate the 706 marking in the document. I have been searching for a few days and it seem as if no one has the answer to the question about only castech making the 706 head. I did locate some pictures that showed different font for the 706 number, but those posters never indicated if they found the castech logo inside.Sorry I can't help more.
    http://ww2.justanswer.com/uploads/Bl...t_loss_5.3.pdf
    Thank you for the reply, I think I found the same thing you did. Seems like you must look inside to properly identify.
    The good news for now I guess is that I'm not loosing coolant. So nothing urgent at this time.
    i don't know if mine falls into this category...i have the 6.0 motor and just recently found a hairline crack on the passenger side head and was losing coolant...good thing it was under warranty...only cost me $75...so it could've been worse.
    Mike - SoCal
    07 Sierra 1500HD
    Ultra Mammoth Wheels 17x8
    Nitto Terra Grapplers - 305/70/17
    Line-X Bedliner and Wheel Wells
    NFab Nerf bars
    CST 4" Spindle lift
    08 Hybrid Tahoe - wifey's ride
    McGaughy's 2/3 drop kit
    22x9.5 Tyfun Wheels
    Nexen Roadians 285/45/22
  1. 2010 Silverado 1500 dash crack.
    By SB09 in forum Chevy Truck Talk & GM News
    Last: 01-02-2012, 09:58 PM
  2. Radiator side tank crack fix.
    By Big75 in forum How-to Guides
    Last: 08-26-2010, 02:55 PM
  3. Crack the VIN for me?
    By vncj96 in forum The Coffee Shop ~ Chit Chat
    Last: 01-26-2010, 10:35 PM
  4. CRACK DVD/NAV 2009 Tahoe
    By bowtie8 in forum Audio, Video & Gadget Tech
    Last: 06-17-2009, 04:30 PM
  5. Automakers racing to crack India’s hot market
    Last: 09-12-2007, 03:01 PM
