    Default Truck won't blow heat down by floor
    Hi everyone. Really digging this site, lots of helpful info. Hopefully someone can shed some light for me on this one.
    I recently noticed that my '00 Silverado will not blow heat from the low vents down by your feet. Up top it is fine, nice and hot and strong. Down by the feet, nothing.
    Thoughts?
    -2001 Suburban 2500 LT 8.1
    -2000 Silverado 1500 LT Z71
    Gone but not forgotten:
    -2007 TrailBlazer SS
    -2004 Cadillac CTS-V
    -1998 Silverado 1500 LT Z71
    -1989 Pontiac Formula WS6
    You might check all of your vacuum hoses to make sure they are connected and/or not cracked. I had a 2000 GMC astro van that did something similar with the AC blowing up out of the defrost, but not the vents/floor.
    06 Chevy Silverado V6 4.3 Reg Cab
    71 Chevy Nova SS 350 SB
    Nov 2011
    Shady Spring, WV
    My Suburban was doing that last year and the blend doors were binding and had to be replaced. Also, one actuator was bad not working the blend door.
    Quote Originally Posted by grape2 View Post
    Interesting. Was this a difficult job? If you didnt do it yourself, do you remember what it cost to have fixed?
    you can get to your blend door easily, it sits right above the transmission hump, just a couple screws and it will open it up and you can see what it is or isnt doing when you switch it to the floor vents. there is a gasket that helps it seal into its different positions, most of the time that had torn and is caught up in the door
    Hypertech III, K&N, true dual
    285/75/16
    ___________________________
    Jason
    Wow, that sounds hopeful. I will investigate tonight. Thanks.
    Apr 2009
    North Dakota
    I have a friend with a 2008 K2500 that just got his blend door problem fixed for the 2nd time. Also his fan would only run on high so it took a resistor/relay worth about $300 to get it working right. $575 total to get it fixed at a GM dealership.
    Quote Originally Posted by donl View Post
    Your friend got ripped off, putting in a new resistor for the fan is easy and cheap to take care of your self, and all you need to know how to do is turn a screwdriver
    [sarcasm]What? Someone ripped of by a dealership? Noooo waaaay! [/sarcasm]
    Coroso did the advice vncj96 gave you help? Usually thats the source of the problem you described.
    Get the Gorilla!
    gorilladip.com
    sales@gorilladip.com
    Quote Originally Posted by sstoner911 View Post
    I haven't had a chance to really get into it. My truck has the center console that runs up under the dash. I looked at it briefly today and it looks like I will have to remove the console to really get at it.
  1. heat prob with 95 Silverado heat then, no heat???need some help!PLZ
    By jteuban in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 11-20-2011, 09:34 PM
  2. Replies: 2
    Last Post: 06-25-2010, 11:30 AM
  3. W/T floor mats for the plastic floor?
    By daweinah in forum Chevy Truck Accessories
    Last Post: 10-30-2009, 08:56 AM
  4. No heat up front, but heat in rear on '83 'burb
    By FUNFINDER in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 04-20-2009, 02:50 PM
  5. Gas pedal to the floor truck won't take off?
    By wakejim in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 02-11-2008, 03:28 PM
