    Newbie
    Jun 2011
    Portland, Oregon, United States
    Question Help- Lifting 2002 suburban
    Hey all,
    I'm new to the club. I have a 2002 Suburban and want to put a lift on it. Im thinking maybe 2 inches in the front and 1 in the back, or 1 inch in the front and none in the back. What kind of parts should I be looking for to do this and what should I know about this procedure? (Side effects, pros, cons, etc.)
    Thanks everyone!
    Welcome to the club. You can raise the front of your burban a few ways. One way is to crank up the torsion bars. The pro for this is the cost. None. Other than an alignment. Another way is to install torsion bar lift keys. This will give you around 2"'s. For $100 - 150 plus alignment. Or there is a spring spacer that could be installed between the coil spring and the chasis.
    http://www.suspensionconnection.com/...tion/to=r.html
    Newbie
    Jun 2011
    Thanks! Will this effect my MPG or horsepower or anything?
    It will not effect your HP in anyway. But, adding larger tires will effect your MPG and generally cause you to wear out front end components faster (ball joints, pitman + idler arms..etc)
    See this thread and scroll down, this guy did exactly what you are looking to do...
    http://www.gmtruckclub.com/forum/sho...-2500-Suburban
    -2001 Suburban 2500 LT 8.1
    -2000 Silverado 1500 LT Z71
    Gone but not forgotten:
    -2007 TrailBlazer SS
    -2004 Cadillac CTS-V
    -1998 Silverado 1500 LT Z71
    -1989 Pontiac Formula WS6
  1. 2002 Suburban Z71
    By BBD in forum Member Introductions
    Last Post: 12-29-2010, 09:57 PM
  2. lifting it up
    By muddmonkey in forum Chevy S10 Forum (GMC Sonoma)
    Last Post: 07-17-2010, 02:24 PM
  3. lifting my gmc
    By dougmc in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 04-24-2010, 08:26 AM
  4. will 98 Suburban 4L60E fit in 2002 Suburban
    Last Post: 09-01-2008, 04:02 PM
  5. 2002 3/4 suburban with 8.1
    By cmevis in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 05-04-2008, 11:53 PM
