Results 1 to 10 of 12
Thread: Help oil issue
    Default Help oil issue
    ok i just replaced oil in my 01 silverado i put in recommended amount but the check engine oil level light is on and the oil is either all over my dipstick or hardly there. i have oil pressure and i do not have any leaks or burning oil. Any ideas?
    Chevy runs deep.
    2001 Silverado ext cab 4.8l v8 2wd
    COMPLETED MODS
    40 series flowmaster dual with bowtie tips
    Anzo tail light
    Fire and ice lighted mud flaps
    2 12inch kicker comps with boston acoustic amp
    TO-DO MODS
    w2w nerf bars
    Headers
    Color-matching
    Headlights
    Mega third light
    Scanning light bar under tailgate
    Fix tint
    Upgrade deck
    Remote start
    High 4 headlight kit
    Rear side window covers<bowtie>
    My velocity is directly proportional to your proximity.
    I am not trying to insult you, but lets start with the basics. After you added the oil did you start the truck and let it come up to pressure, shut it off, pull the dipstick, wipe it, stick it back in, pull it back out and check it? Again I am not trying to insult you by any means.
    Sr. Engineer
    Oct 2010
    Indianapolis, In
    Is this the first oil change in this truck for you? I ask because currious if it is different than norm or if it is the first then maybe wrong dipstick or some other mod you may be unaware of if the truck is new to you.
    I understand and yes i did all that normal stuff.
    ---------- Post added at 08:25 PM ---------- Previous post was at 08:23 PM ----------
    This is the second oil change in this truck that i have done first time was no problem.
    Make sure vehile is on level ground. Let the truck heat up to operating temp then shut it down. Let it sit a minute, Pull the dip stick out and don't bother looking at it just wipe it off and put the stick back in and pull it out. Now check it. If it is high you put to much oil in and will need to drain a little out until it is correct on the stick. If it is to low at this point you will need to add more oil, run the engine, let it sit a minute and check it again.
    Hope this helps
    just out of curiousity? how much oil did you put in, and what weight?
    Hypertech III, K&N, true dual
    285/75/16
    ___________________________
    Jason
    5qt 10w30 plus oil treatment
    My 99 5.3 takes 6qts of oil, does the 4.8 take only 5 or did you not change the oil filter?
    Quote Originally Posted by darkness-lies- View Post
    The Oil Capacity (With Filter Change) on the 4.8 Liter V-8 is......6 Quarts.....per the Owners Manual.
    i thought it says 5qt. wow i feel stupid. ill fix that right now!
    ---------- Post added at 03:40 PM ---------- Previous post was at 03:21 PM ----------
    fixed
  1. I need some help with a cop issue.
    By Chad513 in forum The Coffee Shop ~ Chit Chat
    Last: 08-21-2011, 12:34 PM
  2. Hello, possible TPS issue?
    By Sierra2500 in forum GM Powertrain
    Last: 02-09-2011, 07:48 PM
  3. ABS Issue
    By Lumpo in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last: 09-03-2009, 03:25 PM
  4. Issue with 4WD
    Last: 12-21-2008, 09:26 PM
  5. K&N issue ..??
    By TahoeFever in forum GM Powertrain
    Last: 11-17-2007, 06:59 PM
