Results 1 to 9 of 9
    Default Mild Audio System (Need Battery Suggestions)
    I'm getting my 2 15" Kick comps installed on monday
    there gonna be run by Alpine MRP-M500
    im also considering getting the Alpine SPS-610C and the Alpine SPS-610 installed with the Alpine KTP-445 Power Pack
    with it possibly hooked to Alpine CDE-126BT
    any battery suggestions??
    and should i get a capacitor????
    Quote Originally Posted by peanutbuttersports View Post
    Do not get a capacitor...they are a waste of money. If you want to change batteries I would suggest a Optima Yellow Top. Kinetik and Stinger also make decent batteries.
    I am still using my Stock GM battery and have had no problems. I get a consistent 14.5 volts out of it when playing the system normally...if I crank it up it never dips below 12.5 volts.
    Get the Gorilla!
    gorilladip.com
    sales@gorilladip.com
    Sr. Apprentice redneck70's Avatar
    May 2010
    Regina, Saskatchewan
    Unless your using your stereo mostly with your truck turned off a new battery would be a waste of money, as long as your battery is good and it's not putting any extra strain on your alternator just to keep it charged you'll be fine, if you are getting the lights dimming when you crank it up I would consider get a bigger alternator. When you have any electronic accessory on it's your alternator that has to keep up with the large current demands not your battery.
    If you are using your stereo with the truck turned off most of the time a bigger battery would be a good idea, or better yet put in a second battery so when you want to get your truck started you won't need a boost.
    2007 Silver Birch Metallic Sierra Classic SLE Crew Cab Z71
    Line-X bed liner
    Putco box rails
    Truxedo Lo Pro QT box cover
    Cloud-Rider grill inserts
    Quote Originally Posted by redneck70 View Post
    That's not entirely true. You might have other uses for a battery such as a winch, light bars, and the like. A capacitor won't help in a multi-function scenario. Put simply, a battery is far more extensible than a capacitor, as it lends itself to more uses.
    Sep 2011
    Fairbanks, Alaska
    Biggest misconception about batteries and alternators is people use the voltage value when talkin about electrical efficiency. If you're running any kind of system or accessory it is given that it needs 12.5-14 volts... Systems and accessories are demanding a higher CURRENT flow, that's where more efficient batteries (the word "bigger" is misleading) come into play, also, how are alternators rated? Amps, which is the electrical measurement of current. Why do you think you use bigger power wire for bigger systems? It's not so you can get more voltage to your amp rack, it's to allow more current flow. For the poster, get a better battery and better alternator, you WILL hear a sound difference and your truck will love you long time .
    As said above.. With that one amp You should be fine No worries But if you are going for more power later and More add on's on the truck.. Batt and Alt will cost a bit but are well worth it..
    After over 20 years of being in the 12 Volt world Alt only one I would recamend is Ohio Genartor Simply the Best.. Batt's Kinetik is the way to go...There are a few others..
    if i were to get a second battery on the truck where would i mount it????
    Sep 2011
    Fairbanks, Alaska
    What year/model?
    2006 GMC Canyon 5 cyl.........
    Crew Cab
  1. 09 Silverado: Tailight and Audio Suggestions?
    By blaketg in forum Chevy Silverado Forum (GMC Sierra)
    Last: 06-05-2011, 11:18 PM
  2. Suggestions on aftermarket audio.
    By Jay in forum Audio, Video & Gadget Tech
    Last: 02-03-2011, 02:28 PM
  3. 03 Audio System
    By HawaiiKid in forum Chevy Silverado Forum (GMC Sierra)
    Last: 02-09-2010, 02:00 PM
  4. 2009 Silverado audio system with ipod integration by JML Audio of St. Louis
    By jmlaudio in forum Audio, Video & Gadget Tech
    Last: 06-28-2009, 10:54 AM
  5. Audio System
    By Rumpamuro in forum Audio, Video & Gadget Tech
    Last: 08-18-2007, 09:35 PM
