Thread: Radio reception
    Jr. Engineer Jaele's Avatar
    Nov 2011
    Fairfield CA
    Default Radio reception
    So I purchased a 2011 silverado back in June. It came with XM radio after that expired I used the FM Radio and I noticed that when it's cold out side I have zero reception. I check the antenna and connection and there is no corrosion, anyone have any ideals???
    Thanks
    Jaele
    2011 Silverado 1500 Z71 4x4 Crew Cab
    LED Dome light
    LED Floor lights
    RC Leveling kit
    Tow Mirrors Custom LED running/signal lights
    BakFlip G2 Tonneau Cover
    You have a warranty, take it back, dont say you even touched, they may try and say you did something while pulling things apart
    Hypertech III, K&N, true dual
    285/75/16
    ___________________________
    Jason
    Quote Originally Posted by Jaele View Post
    Thanks
    Jaele
    This is actually quite common. Your not the only one to experience it, including myself. There are alot of theories, some say its condensation in the antenna or XM brain itself that once the unit warms up eliminates the condensation.
    Since your under warranty I would see if the dealer will maybe have some insight to the problem. It has been a long time since mine has done it..but then again it doesnt get very cold here in Tucson Arizona very often.
    Get the Gorilla!
    gorilladip.com
    sales@gorilladip.com
    Nov 2011
    Fairfield CA
    So I forgot to update everyone on this issue. It took two separate trips to the dealer to find it, and its still going to take one more to fix it. They found a crack in the antenna cable that was getting moisture in it of course they had to order it and then said its going to take 4-6 hours to replace the bad cable. The tech told me he would have to disassemble mos of the dash, go figure. haha
    Well, at least they figured it out and you're getting it fixed. Fortunately I never had that issue and my truck's in the seattle area so it gets fairly cold in the winter. Sometimes it's nice to have that warranty.
    To Be Completed (Eventually):
    Yup, the antenna cable comes from the antenna mount point into the dash and snakes its way to the radio location. Someone with small hands (like me) can work through the vent openings (after removing the vents, of course) to maneuver the cable ... as well as work from the floor up behind the airbag and OnStar unit. However, I've noticed that most mechanics don't have small hands.
    Nov 2011
    Fairfield CA
    HAHA so i finely took the truck into the dealer to get it fixed. Turns out the cable was not installed correctly and got pinched when they installed the IP. Some how they managed to cover the bolt hole with the cable and then cut/pinched the cable when they had to force the bolt in. Not sure if this is done by machine or a person either way its kind of strange.
    Bleah -- that's atrocious quality control either way.
  1. Radio reception SUCKS!
    By Blue05LT2 in forum Audio, Video & Gadget Tech
    Last: 02-23-2011, 10:42 AM
  2. Improving Radio Reception in Your Car - Wall Street Journal
    By ChevyFan in forum Chevy Traverse Forum (GMC Acadia, Buick Enclave)
    Last: 05-18-2010, 10:30 PM
  3. Poor Reception
    By midwest in forum Audio, Video & Gadget Tech
    Last: 02-15-2009, 11:43 AM
  4. Better antenna for radio reception
    By Hummer in forum General Chevy & GM Tech Questions
    Last: 08-11-2008, 01:26 AM
  5. Sirius radio connected to radio with XM
    By HitchHiker in forum Audio, Video & Gadget Tech
    Last: 09-18-2007, 08:55 PM
