Results 1 to 10 of 11
    Default Rear and Front Dif.
    Alright, so i experienced this for the first time a week ago. I was going up a ramp ( that kind that goes in circles) and i started hearing this horrible clunkcing noise in my dif. my left tire was skidding. So i stopped and put in 4 wheel. It did the same thing. when i finally got on a straight away, it stopped.
    Does this mean i got a bad dif. ( i'm going to school for mechanics so i understand how it works) i've never really experienced this before. I've heard th g80 is a good dif, but would it be beneificial to swap out my stock dif.
    2002 Gmc sierra
    5.3 v8 1500
    k&n air intake
    20inch liquidmetal dyno 6's
    xlerator dual exhaust.
    I would check to make sure the fluid level is correct. Than I would pull the diff cover to check the gears.
    The G80 is by no means a good diff. It has many small, fragile parts inside, and has been known to fail with even normal street driving. It can behave like you are describing when it does.
    78 GMC High Sierra K1500
    I changed out the fluids last year and I did top it off. This only happens when one tire is on slippery and one isn't and then when it does get traction i still get clunking noise, and then goes away. Is there any better diff i could install that would allow power through it and is more sturdier.
    2002 Gmc sierra
    5.3 v8 1500
    k&n air intake
    Apr 2009
    North Dakota
    When was the last time you changed the rear differential fluid?
    Almost a year ago. I might change it again this spring, and take a look at the dif. but, i kinda want a new diff though. ones that are indestructable and actually work.
    2002 Gmc sierra
    5.3 v8 1500
    k&n air intake
    If you want a limited slip a real good one is the Detroit Trutrac. Its uses gears instead of clutches so it'll last the life of the truck. If you're looking at a locker avoid the automatic ones such as the Detroit Locker. They can cause handling porblems on slick roads. I'd recommend a selectable one such as the Eaton Elocker or the Auburn ECTED. The Elocker functions as a open diff when off and locks when activated. The ECTED is a limited slip when off and locks when activated.
  1. No Heat front or rear
    By djssub in forum General Chevy & GM Tech Questions
    Last Post: 01-25-2011, 11:02 PM
  2. Blown Front Rear
    By eddie mercury in forum GM Powertrain
    Last Post: 01-10-2011, 01:48 PM
  3. front and rear bumpers
    By philsz71 in forum Chevy Truck Accessories
    Last Post: 02-16-2010, 01:11 AM
  4. Ride height front and rear
    By Coneklr in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 08-31-2009, 06:51 PM
  5. Front or Rear Leveling??
    By flag8r in forum Lifted & Offroad Suspension
    Last Post: 04-16-2008, 03:11 PM
