Page 2 of 4 FirstFirst 1234 Last Post byLast Post by
Results 11 to 20 of 34
    I got Rhino Liner a week ago based on my buddy's experience. He had minor damage repaired under warranty. A 'newer' product formula was used for the repair .. the stuff is flat-out bulletproof! Cost on mine wasn't too bad either .. $425.
    - Ted -
    2005 Silverado 1500 Z71 Ext. Cab w/272K
    Jan 2011
    Lake Conroe Tx.
    My spray in bed liner is getting chips, and it does not look good. Can a new liner be sprayed over the old liner? Or is there a way to remove the sprayed in bed liner
    I don't know if they remove the old liner, but whatever is done is covered under warranty. When I was shopping, if there was no lifetime warranty, I dropped them from consideration no matter what the price was.
    LINE-X Premium
    Unlike Rhino, LINE-X Premium holds its color and gloss. Also, LINE-X is WAY stronger than Rhino. Specifically, LINE-X has a 31% higher tear stength, a 53% higher tensile strength, and a 45 degree higher temperature tolerance. (I have the products' technical data sheets.)
    I had a Rhino Liner in my 2003 Silverado, I abused the crap out of it using it for work and never had a single tear, or any problem.
    When it comes to Line X I haven't heard anything but good reviews either. I think that you will be happy with either one you choose, but the Rhino Liner is the only one I can recomend from experience.
    Ext Cab 4wd LT
    Check out my garage
    http://www.NStarWindow.com
    Think I'll be going with the line-x, but do you know how much it would be to color match?
    2011 GMC SIERRA CREW CAB 2WD W/5.3
    Convenience Package
    : Adjustable Pedals, Remote Start, Electric Rear Window Defogger, Rear Parking Assist
    Power Tech. Package| Volant CAI| GMC Upgraded Grill| Line-X Premium Bedliner| AVS Smoke Headlight Covers| Demolded| AMI Black Grill Emblem| AMI Black Rear Emblem| EGR In-Channel Window Visors| IPCW Third Brake Light| IPCW LED Fiber Optic Tail Lights| IJDM Dome & License Plate LED's| Flowmaster Exhaust W/ 3" Black Chrome Tips| OEM 20" Rims W/ Goodyear Eagle LS2
    You can't get away from the STORM!
    they got some on ebay at a good price we sprayed a 84 with it its held up real nice.im fixin to paint my 67 with it green and black.let try to scrath that in a parking lot.
  8. #18
    I did a lot of research before I did my 02 in 2003. I got samples from rhino and line-X. I was a bricklayer at the time and used a lot of chemicals like Xylene. I put the samples in a bucket of xylene for 4 days. When I scooped the samples out I found that the Line-x was still perfect, The rhino had become goop. I went with the line-x. If i spill a bucket of xylene on the rhino, I would not have a liner for long. It has been almost 10 years and it is still in great shape. I load it with brick and block all the time. One thing that I found out when doing my research was the rhino is sprayed in cold, while line-x is sprayed in hot. Line-X can be sprayed in thicker without dripping or running. Line-X has a lot finer finish compared to the rhino that my brother bought. (His has peeled multiple times in 8 years). It seems as if line x is a lot harder finish. I helped my brother unload a yard of dirt from his bed and my shovel kept getting jammed in the rhino, and I peeled a spot back. (with a flat shovel). Has never happened with the line x. Only thing about line x is you have to be careful loading furniture with wooden legs, you can actually grind the bottom off the legs sliding the furniture in and out.
  9. #19
    Quote Originally Posted by DannyT08 View Post
    i got a buddy that has grizzly grip in and on his truck its been through hell and back(im bout to buy some wit my tax return) but its a do it ur self kit come with everything and u can choose a color if u dont want black... its www.grizzlygrip.com comes wit pretty much everything u need check it out its pretty good stuff
    I just might get that and do some areas that get beat, before I do the bed. Does it leave roller marks, is it thick enough or do you have to do more coats.
    Tim Walters (Curky)
  10. #20
    thats what we bought off ebay was line x we shot the whole truck.about six months ago still looks the same as the day we sprayed it.soon as i get the body work on the 67 done i am going to shoot it to.
    ---------- Post added at 06:05 PM ---------- Previous post was at 06:03 PM ----------
    line x sprays on with a gun.
  1. Best spray in liner?
    By seanhill1969 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 11-07-2011, 02:04 PM
  2. Spray on bed liner
    By Chevy Newby in forum Chevy Truck Accessories
    Last: 10-01-2010, 02:14 AM
  3. Reflex spray-in liner
    By toleo in forum Chevy Truck Accessories
    Last: 05-17-2010, 11:47 AM
  4. removing spray in bed liner?
    By ThatSilverStepside in forum General Chevy & GM Tech Questions
    Last: 02-03-2010, 10:32 PM
  5. What is a good spray on bed liner?
    By nos351wcm in forum General Chevy & GM Tech Questions
    Last: 01-31-2010, 09:07 PM
