Results 1 to 10 of 22
    Sr. Apprentice DanPruski's Avatar
    Jan 2012
    Wasilla, Alaska
    Default 1993 K1500, Manual 4x4 lever and it wont enguage in 4x4 when i pull the lever.
    Front driveshaft enguages in differencial but will not spin the front tires. Acts like its in 4x4 meaning in 4L i can only go 10MPH, and 4H i can feel it enguaged, but the front wheels wont spin with the back.
    Checked the fluid in the front diff, gears, ujoints, tcase fluid and gears, and checked the CV's on front, and TCase linkage.
    I was told it may be some "plunger" on the front "axle"
    makes driving in winter a pain any help would be appreciated.
    There is a actuator on the front diff. It's on the front passenger side of the case. Unplug the wiring and check if its getting voltage when transfercase in in 4wd and engine is running. If you do its the actuator, if not its in the wiring or a fuse.
    78 GMC High Sierra K1500
    Jan 2012
    Wasilla, Alaska
    okay, is the actuator on the diff-case, or on the small "axle" on the passenger side?
    and to test it just unplug it and test for continuity at the plug with the engine running and in 4X4, or can it be done with just the battery on?
    shift it into 4x4 and make sure the front wheels on the little picture of the truck by the shifter are lit up, then leave the key on and go test it. you will see the wires going into the front axle, i forget exactly where the actuator is, i think its on the little axle on the passenger's side, but don't quote me. but i swear, you wont miss it lol
    Quote Originally Posted by cooter71 View Post
    in theory if the actuator is not working the indicator should not light up as the solenoid trips the light switch, i guess its possible that the actuator may move enough to turn on the light but not have enough power to shift all the way to lock in the diff
    my 88 sas "mudwasp"
    bouncing truck avatar creator
    Jan 2012
    Wasilla, Alaska
    The light wont come on for it which makes me think the actuator is fully bad, not just partially.
    Is there any way to bypass that actuator? Or is it absolutely needed for the system to work?
    05 Silverado 1500 LS 5.3L.
    6" fabtech lift, 35x12.5 Nitto Mud Grapplers, 20x10 XD Monster wheels. MagnaFlow dual exhaust, AEM cold air intake, custom tune.
    35W 5K HID low,fog, 55W highs, Hi-6 Mod, black tail lights.
    Color matched front and rear bumper caps, fully debadged.
    5% tint all around, 35% full windshield with 10" 5% brow.
    7" pioneer touchscreen Double Din, 2 Rockford R1-12's under the seat with Rockford P300-1amp, Rockford prime speakers all around, LED interior Lights.
    you need either a actuator or there is a mechanical system called a posi-lok that changes to a cable activation from the cab, those are pretty much your two options
    Apr 2009
    Quote Originally Posted by outalne94z71 View Post
    If I remember right, you can also switch to a manual hub for a TON of money. I used a posi-lok in my old Dodge and I would recommend it to anybody. Easy to install and works great. Should only be a little over $200 if I remember right, which is about a quarter of what a manual hub kit costs for that year of truck.
    2005 Chevy Silverado W/T
    Planned mods not in order
    Quote Originally Posted by Jimmeh View Post
    manual hub kits are for trucks that are solid axle, no such thing for a ifs chevy, the hub does nothing, its is like a front wheel drive car hub, the diff lock is in the differential axle tube and a plunger locks it in.
    Apr 2009
    Thanks for the clarification.
  1. pushbutton vs lever
    By jswilson in forum General Chevy & GM Tech Questions
    Last: 03-16-2012, 05:01 PM
  2. Replies: 0
    Last: 10-28-2011, 02:20 AM
    Last: 10-18-2011, 03:12 AM
  4. What does it take to get instant 4wd when lever pulled?
    By 92WT in forum Chevy C/K Truck Forum
    Last: 02-10-2010, 01:13 PM
  5. shift lever question
    By alberto3a in forum GM Powertrain
    Last: 08-03-2009, 07:11 AM
