Results 1 to 2 of 2
    Default Noise on driver side under load
    I have a strange noise just on the driver side while under load. If I stop put in park and rev there is no noise. Kind of sounds like its coming from the exhaust but doesn't really sound like exhaust leak. Truck is 09 silverado with 4.8l.
    Take a passenger with you and see if it's only on drivers side. Many "drivers side" noises are only on the side that they can be heard on, but really on both sides. If it sounds off more under load, it could be an exhaust leak at the manifold or header pipe or O2 sensor. It could also be a knock from the sh*t we call gasoline nowadays, check for a knock sensor code. If it's a loose spark plug, you will know soon.
  1. Driver side A/C stuck on hot, passenger side fine-2005 Silverado manual dual temp
    By person197 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 12-04-2011, 05:41 PM
  2. Noise at high speeds in front driver side wheel area
    By ccpotter in forum Chevy Silverado Forum (GMC Sierra)
    Last: 10-10-2011, 08:42 AM
  3. Rubbing noise when rolling down driver side window
    By eanderse in forum General Chevy & GM Tech Questions
    Last: 05-11-2011, 09:53 AM
  4. ticking noise under load!!
    By canucks324 in forum General Chevy & GM Tech Questions
    Last: 09-25-2010, 09:26 PM
  5. Ticking noise under load...
    By Agent in forum GM Powertrain
    Last: 03-14-2008, 04:48 PM
