    Default oil pressure on 07 silverado 5.3
    What's the normal oil pressure supposed to be at idle?? Is it supposed to go up when at higher Rpm and down at idle? Help would be appreciated...might be normal but paranoid lol thanks again
    Mine runs around 40-60 when I initially start it and then about 35 idling. Its normal for it to change as the RPMs increase.
    2008 Ext. Cab Silverado LT1 5.3L 2WD
    APC LED Tail Lights | Spec D Smoked Third LED Brake Light | aFe Magnum Force Stage 2 CAI
    With 5W- oil in it and hot, I get about 25 P.S.I. at idle. It cracks at about 40 when at speed. I haven't looked at the insides of mine, because it doesn't leak, but I use full synthetic and doubt it has any build-up at all. It's very important to change oil and filter regularly and have a good 210 degree thermostat to keep sludge to a minimum. If your engine runs cooler, you will need to change oil sooner.
  1. 2006 silverado oil pressure
    By Nathan Kenney in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 07-27-2011, 08:32 AM
  2. What is normal Oil Pressure for 2010 5.3L Silverado
    By alkaspeltzar in forum GM Powertrain
    Last Post: 12-02-2010, 11:45 AM
  3. 99 silverado 5.3l with oil pressure light on
    By 99silv53 in forum General Chevy & GM Tech Questions
    Last Post: 03-23-2010, 05:37 PM
  4. 88 Silverado low oil pressure after heated.
    By twofeathers in forum General Chevy & GM Tech Questions
    Last Post: 10-05-2009, 02:25 AM
  5. '07 Silverado 4.3L low Oil Pressure at idle
    By DaveH in forum GM Powertrain
    Last Post: 06-27-2008, 01:32 AM
