Results 1 to 9 of 9
    Default want change 4wd to a 2wd what do i need to do?
    i have a 2001 gmc sierra that i want to take out the 4wd an do a 2wd in it.
    Put the selector in 2wd.
    Other than that its removing the front diff. and swapping 2wd knuckles (may not have to would have a hole where the front cv joint was) remove front drive shaft. if you wanted to remove the transfer case you would need to swap out the rear drive shaft so it goes from the transmission to the rear diff instead of the stock setup. Im sure there is more.
    David
    1960 Land Rover Series II 88
    2001 Pontiac Sunfire
    NRA Life Member
    Just curious, why would you want to do this? I'm not sure you can just swap knuckles. The 2wd drive suspension is different from a 4wd (coil vs torsion bar and different geometry). You can't just pull the c/v halfshafts because you need the spindle nut to hold the bearing together. So you'll need to keep the front diff and halfshafts. The transmission will have to be swapped with a 2wd unit so you attach a driveshaft or you can get a 2wd mainshaft, tailhousing, plus other small parts to convert your current one. You'll also destroy any resale value on the truck. I think you'd be ahead money wise to sell your truck and get a 2wd.
    78 GMC High Sierra K1500
    Sell it and buy a 2wd, i cant imagine it will be hard to sell a 4wd in Anchorage, although i dont think i would want 2wd only in Anchorage?
    Hypertech III, K&N, true dual
    285/75/16
    ___________________________
    Jason
    well my truck is going to be a summer truck an i want it to be a 2wd so i can drop it lower with out baggs because i want to do a static drop on it an i couldnt sell it for the amount i would want to sell it for due to it be a reconstruct title. so thats why i want to change it an as far as front suspension my buddy has a 2wd with torsion bars not coils. so i dont know about that.
    Probably the best way to do what you want would be to find a 2wd frame and axles then drop your engine and body on, you'll still need to swap the trans or get a long tailshaft.
    Sr. Mechanic
    kburb's Avatar
    May 2010
    Blythewood SC
    Isnt there a law againts this!!
    91 Suburban
    D44/14BFF w/Disc conv - Yukon 4:88's - Yukon Grizzly Lockers F/R -13" lift - DIY4x Shackle Flip - 37 ATZ on 18 MT Classics - Doug Thorley headers - Magnaflow - Holley Pro Jection Intake - Ultimate TBI mods - Hydroboost Brake Conversion - Hysteer-X Over Conversion.
    (Coming up - Fuel Injected 383 Stroker - Divorced NP205 - D60 - 40" tires)
    Quote Originally Posted by kburb View Post
    X2 but it your truck so good luck
    Chevy runs deep.
    2001 Silverado ext cab 4.8l v8 2wd
    COMPLETED MODS
    40 series flowmaster dual with bowtie tips
    Anzo tail light
    Fire and ice lighted mud flaps
    2 12inch kicker comps with boston acoustic amp
    TO-DO MODS
    w2w nerf bars
    Headers
    Color-matching
    Headlights
    Mega third light
    Scanning light bar under tailgate
    Fix tint
    Upgrade deck
    Remote start
    High 4 headlight kit
    Rear side window covers<bowtie>
    My velocity is directly proportional to your proximity.
    Not yet but dont give the politicians in Washington any ideas!!
  1. Replies: 7
    Last Post: 11-29-2010, 07:44 AM
  2. Replies: 30
    Last Post: 11-19-2010, 09:13 PM
  3. How many miles before you change your oil? oil change interval.
    By PaUltraBob in forum Maintenance & Upkeep
    Last Post: 11-01-2010, 05:34 AM
  4. Oil Change at Texas Oil x Change
    By Steve in forum Chevy Compact Cars (Aveo & Cobalt)
    Last Post: 06-11-2010, 03:30 PM
  5. Job Change!!
    By GWAGON_99 in forum The Coffee Shop ~ Chit Chat
    Last Post: 04-08-2007, 09:25 PM
